A few pics of my Fox/LS1 build
#222
hey im doing a sn-95 ls1 swap and am in need of help as far as mounting the motor. who all makes swap k members. also ive heard of modifying the stock 4.6 kmember. if anyone knows about modifying the 4.6 i would love to get some info. if anyone can help id appreciate it.
#223
Quite the saga! Nice job on the install I personally was impressed with your homade tranny mount with the U channels for the exhaust. I read the whole thread and was really suprised you yanked out the LS. You must really enjoy working on cars.
.......Oh and nice looking family too!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#225
I bought the Racecraft one... It is smaller in diameter than the Flaming River and leaves more room for clearance. It also is extremely hardened, it took 4 cut off wheels to cut it to the right length. I think if I had a chop saw, it would have been easier, but I didn't. It also melted 4 titanium drill bits trying to drill the hole for the bolt. Once it was in, it fit perfectly.
You can see the shaft in the right of the picture. I will take a pic, now that it is installed.
![](http://i10.photobucket.com/albums/a149/qwiknotch/lxroller/lx007.jpg)
#226
not to bring up a dead subject, but has anyone thrown a ls with a 4l60e in a stang? im leaning towards the mustang swap, and have a performabuild trans that i got a while ago for a ltx, which i will be swapping the housing for a lsx housing. does anyone know if they sell a trans cross member premade? i dont have a welder/or the know how to fab one up just curious
#227
Well with wiring harness back from Speartech (awsome btw) and the PCM back from Wait4me . I was able to get most of the wiring ran and the PCM mounted. I had a issue with mounting the PCM in the stock mustang location. The 98 PCM if freaking big! I ended up having to clearance the fire wall where the heater core inlet and outlet goes through because I had to shift the whole box over about 1". I started to just leave the box out, but after thinking about those cold mornings getting off of work I came to my senses.
Tipsy
#228
I looked but couldn't find any pics. I basically stuck it in the factory hole and took a piece of that 1" wide banding that you buy in a roll and strapped it in. You WILL have to move your heater box towards the drivers side if you mount it in that location. Its a pita...
If I do it again I'm going to add about 4' to the harness and put it under the passenger seat.
#229
Is there any detriment to having it under the hood...other than aesthetics?
Thanks DJ.
Tipsy
#232
