Need a FWD manual transmission for an LSx
Old 10-10-2007, 02:52 PM
white_fly's Avatar
Default Need a FWD manual transmission for an LSx
I am looking at power options for a open-wheeled car to compete at the Pike's Peak International Hillclimb. Pushrod engines are highly favored so I'd like to use one. I'd like to mount the engine behind the driver but can't afford a purpose-built transaxle and I don't like the idea of using an old Porsche 'box and conversion kit. I'd also like to mount the engine transversely. I know about the LS4 but I don't believe that it is available with a manual transmission. I need a true manual, not an electronically shifted auto. Do I have any options?
Old 10-10-2007, 03:17 PM
Schitzo's Avatar
I doubt there is a FWD trans out there that will mount to the LS1. Your best bet would be an engine trans adapter. What comes to mind is the route taken by Fiero guys.
Check out what this guy did.
http://www1.freewebs.com/fierols1/cradleworkday.htm
adapters
Old 10-10-2007, 03:48 PM
V8Rumble's Avatar
First thought that comes to my mind is to see if you can use an adapter plate to mate the engine up to a transaxle from a late-60s Toronado... I'd guess that that would be able to take the torque (esp. in a lightweight car), but I don't know if you'd need/want more than three speeds...
Good luck, I'd like to see it run!
(OK, scratch that, I looked right past where you said you wanted a manual trans.)
Old 10-10-2007, 05:40 PM
stevieturbo's Avatar
Gardner Douglas in the UK build kit cars and use various LS motors in their builds.
They use some sort of Porsche Transaxle in those.
http://www.gdcars.com/html/intro.htm
Old 10-11-2007, 11:10 AM
Derek 357i's Avatar
Some new pontiacs come with an F40 6 speed gearbox. I am not certain if they mate up or not.
Old 10-11-2007, 11:25 AM
jeepinpete's Avatar
An LSx will not mount up to the Pontiac F40 6 speed, but there is a kit out there to use it. That tranny is also your best bet strength wise for a transverse drivetrain setup. Contact Archie at http://www.v8archie.com/ I do not see any info listed on his website, but he does offer the conversion kit for the Fiero crowd.
Old 10-12-2007, 10:22 AM
jmarsa's Avatar
How about the LS4 and an aftermarket trans controller with paddle shifters? I would think an auto would work as long as you could up/downshift immediately on demand.
--JMarsa
Old 10-12-2007, 10:31 AM
dlove's Avatar
just hit the FWD button
Old 10-12-2007, 12:54 PM
TheAntiRice's Avatar
i thought i was the only one with one of those lol
Old 10-12-2007, 06:53 PM
white_fly's Avatar
--JMarsa
I don't want to do an auto because it takes alot of driving techniques that are possible with a third pedal and throws them out the window...techniques that are especially valuable in a low-grip environment. There's nothing quite like clutch-kicking a car into a lurid slide and you just can't do that sort of thing with an auto.
However, I like the F40 idea. Will be looking into that.
Old 10-12-2007, 09:51 PM
89 formula350's Avatar
G-force sells a man. trans for fwd. I don't know much about it other than it will hold some unreal TQ. I may be off on what you need however it's worth a look
Old 10-12-2007, 09:56 PM
Kamin's Avatar
lol dude i had to fix your sig image, the smoke was way too crappy at the end.
Old 10-12-2007, 10:08 PM
2002_Z28_Six_Speed's Avatar
Don't count on a Getrag to get you where you are trying to go. Better off with a automatic transaxle by far.
Old 10-13-2007, 07:18 AM
Lincoln's Avatar
Do some searching on Pennocks Fiero Forum.
http://www.fiero.nl/cgi-bin/fiero/Ul...i?action=intro
We haven't found a manual trans that can take any abuse. If you want a manual trans the Porsche is your best bet.
Old 10-13-2007, 12:38 PM
http://www.g-forcetransmissions.com/tran_gt-50.asp
this is what I was thinking of but I see it's not gonna work anyway
Quick Reply: Need a FWD manual transmission for an LSx
