LS1& T-56 into a 1969 impala wagon.
Just some info Im tossing around in my head. A 2000-2002 ls1 & 6 speed take out and put in a 1969 chevy inpalla wagon.The wagon used to be a 327 & 3speed on the tree.Would like to upgrade.Car would be used daily to go to work in all kind of weather.Inportant to me is dependability , good milage around 20 hwy and 12to15 city.Im thinking of a good cold air intake a set of full lenght headers.Change the shifter to somthing longerto fit in the car.Rear in the car would be changed to a 4:11 rear and posi.So my question i what to you think.Could any of you suggest a cam for this.ANY thoughts would be cool.Thanks to all.Heres a picture of when I pulled It out of garage in Pittsburgh after being in there for 30 yrs.Looking for any suggestion.thanks
Great idea! I love wagons and this one is gonna be killer. Ls1 and M6 will be a great combo. Your mileage goals are very attainable. Are you going to stay injected or run a carb? Best of luck with the build!
I want to stay injected.Im looking for suggestions for cams and headers to try.I want to make the instail look clean .I want this to be right.I want to be abail to run this on the Hot Rod Powertour.Maybe run a high 13 in the 1/4 mile.
I haven't seen very many threads in this forum with guys putting LS1s in B Body cars. I'd be curious about what oil pan and headers would clear the steering linkage.
Man that LS1 will look tiny in that huge engine bay! My '67 with a Big block gives me acres of room to spread out and work on.
I am putting a 6.0L/4L80E in a 70 Impala (=same car, apart from the face lift).
The oil pan was the main problem because the car is a rear steer, I had to cut the truck pan a lot to clear the centerlink.
For headers, I used '70 Impala big block headers, modified to mount on GMPP LS1 exhaust flanges: pretty close, only about half the pipes needed to be cut a bit and rewelded.
I have used motor mount adapters from Transdapt, easy, no sweat, leaves a good 2" between rear of block and firewall, enough to lift the engine to install oil pan!
The engine fits in place with the stock A/C suitcase and the stock master cylinder/booster; I did have to remove th rear driver side coil to swing the engine in place, but that's it.
I am using the stock trans crossmember, just moved a few inches to line up with trans.
Got any pics of the oil pan and how the steering clears?
Thanks for the Invaluable info.My wagon doesnt have AC so it should be a little better fitting it in.I have looked into 1969 Camaro BBC headers & depends on the brand They seam to be the same Part # as the Impala BBC headers.I know they make LS1 headers for Camaro so I was thinking these would fit. Being able to use BBC headers helps with the cost.You gotta let us know how this runs.The room of the big car and a LS1 would make a great car.I also have a 1970 Caprice.Its a 454 car with power windows,locks,seat,trunk,tilt wheel,cruise,and posi.I put the largest sway bars I could find and heavy duty springs front and rear.Added a 1985 Monte Carlo SS steering box to it and the car handles great.I added a 700r4 and 3:55 gears in the rear.I get about 10 MPG in the city but 18-19 on the road.Great cruzzer.I would like to see some pictures of your stuff.I think there would be alot of interest in B body car LS1's.
Hey Mesa that wagon looks like GM did it.Great job.What kind of tranny and what kind of MPG do you get driving it? Does it hall AZZ.Yes I would like some pictures of the swap.Can you put the pictures on a photo share website so I could(and a lot of others)could look at them at any time?
I used the 4L60E. The mileage on the road is 20 plus. I had Speartech do the wiring harness and reprogram the computer. The car weights 4300 lbs and has a lot of lowend torque. Performance wise I can beat a Dodge Hemi without any problem. I will organize my photos and post them soon for you and anybody else that is interested.
