Another LS1 foxbody thread
Old Nov 16, 2007 | 03:50 PM
mark_fox's Avatar
Default Another LS1 foxbody thread
Hey guys, I'm new to LS1 tech and I had a few questions. I've been using the search feature and reading about as much as i can before i posted a thread, i was just looking for some definite links or ideas. What i want to do is put an LS1 into my 88 Mustang GT and turbo it. The couple questions i had were:
What motors mounts do i use?
Do they make swap crossmembers?
I'd like to run a T56 but would the driveshaft have to be modified at all? What about where the shifter goes? Or any of the clutch components since the car currently is a 5 speed?
I'm planning on running it carburated and i found an intake and timing control box from edelbrock so i'm probably going with that route. Is there anything else i have to worry with wiring?
Would i need all new gauges / new dash to fit those gauges?
For cooling, i read a 99 Camaro radiator and hoses would fit with minimal modification. Can anyone confirm or deny this?
I am in the process of finishing a 351windsor but the price of race gas on a college students budget is just too much. And after beating a Lamborghini Murcielago in my friends turbo Trans Am, I was converted. Any help is greatly appreciated guys and thanks in advance!
-Mark
Old Nov 16, 2007 | 04:54 PM
djquik88's Avatar
You can check out my tread . https://ls1tech.com/forums/conversions-swaps/777541-few-pics-my-fox-ls1-build.html It answers most of your questions.
Old Nov 16, 2007 | 06:23 PM
mark_fox's Avatar
Thanks man! What trans are you running? Car looks great
Old Nov 16, 2007 | 10:39 PM
djquik88's Avatar
I am running a T-56. As far as the driveshaft goes , I had to have one made. I used the stock Camaro slip yoke , but bought a new beefier flange for the 8.8 . Mine was 44 1/2" long from the cap centers . And thats useing the AJE k-member and mounts . If I remember correctly it cost me less that $200 to have it built .
Mike
Old Nov 16, 2007 | 10:47 PM
mark_fox's Avatar
What about the shift boot and all of the shifter related things? Do they line up fine on the T56? Any cutting necessary?
Thanks for the help guys
Old Nov 16, 2007 | 11:31 PM
djquik88's Avatar
I had to cut the rear of the original opening on the trans tunnel back a few inches .
Check out this tread -> https://ls1tech.com/forums/conversions-swaps/588161-ls1-mustang-swap-article-popular-hot-rodding-magazine.html
This is the build up of the "Orphan" that was in PHR mag. Powershiftkung has a few pics of the shifter clearance issues.
Old Nov 17, 2007 | 02:44 AM
1dirtyZ's Avatar
as for the radiator , it will fit without issues as well as the hoses . all you have to do is tilt it a bit ( bottom part will sit where the ford ac condenser usually sits) and use the stock ford radiator hold downs.
motor mounts: use the 4.6 mounts from a 96 and up stang ( get the poly ones for a more rigid mount), 2 of the three bolt holes will line up with the hole sin the block , but the third one needs a small plate or extension to reach the other hole in the block.
guages: the fuel and volts guages in the dash will work and you could hook up the oil pressure guage . the rpm guage doesn't go up high enough and the speedo is cable operated, so its a bit hard to make it work. you can use the stock guage pod or enclosure and put your own guages ( look at what brains did - awsome work! look up www.ls1mustang.com)
Old Nov 17, 2007 | 10:43 AM
mark_fox's Avatar
1diryZ, wouldn't it be easier to use the AJE crossmember and swap mounts they supply? This is all new to me so i'd like to get opinions on what would be the easiest.
Old Nov 19, 2007 | 02:43 AM
1dirtyZ's Avatar
i used the AJE 4.6 member and used 4.6 mounts. this setup ( i beleive) sets the engine as far back as possible. in my case the passenger head is about 1/2 to 2/3 of an inch away from the firewall.
using the aje swap k member will most likely ( not sure on this) move the engine a bit forward in the compartment.
Old Nov 19, 2007 | 07:09 AM
lt4malibu's Avatar
mine is right up against the firewall with the AJE, i can barely get my hand behind the head...
Old Nov 19, 2007 | 04:32 PM
djquik88's Avatar
With the AJE swap k-member , I can see the head of the bell housing bolts from the top. A couple inches is a big deal..... exp when you go trying to throw the console in and modifying the shifter handle.
Old Nov 19, 2007 | 10:11 PM
mark_fox's Avatar
Do i have to get an aftermarket oil pan or just a stock LS1 will work?
Old Nov 20, 2007 | 07:29 AM
djquik88's Avatar
Stock F-body pan.
Old Nov 24, 2007 | 02:49 PM
mark_fox's Avatar
Cool thanks for all the information guys.
