LSX oil pans
Old Nov 2, 2010 | 04:05 PM
  #301
philntx's Avatar
John,
The one I posted was one from the Hummer, not the LS3 Camaro.
Old Nov 2, 2010 | 04:16 PM
  #302
Beau@SDPC's Avatar
LS1Tech Sponsor
But you had the PN for the camaro pan. It is quoted in 2 diff posts. Just wanted to make sure everyone has the right info.
Old Nov 3, 2010 | 08:38 PM
  #303
speedtigger's Avatar
Old School Heavy
Default A new LSX Hot Rod pan from Holley? ! !
How did Holley sneak this one out without anyone knowing it was coming? I found it while looking at the new intake manifolds Holley is coming out with for LSX motors. Check it out!
http://www.holley.com/SEMA/Pictures/...adquarters.pdf
Here is a video of the pan I found on You tube:
http://www.youtube.com/watch?v=6QNyhrJWMOk
Here is the Holley promo ad from their website
Old Nov 3, 2010 | 08:58 PM
  #304
garys 68's Avatar
OK question, is this just a Holley badged version of another aftermarket pan?
And will the price be competetive with the $130 LH8/H2/muscle car pan? I'm doubting that part......
Old Nov 3, 2010 | 09:07 PM
  #305
Old School Heavy
I don't know what swaps the LH8 pan is actually good for. Everything I have heard about that pan is that it is way too deep and has all kinds of ground clearance problems. Most of the Camaro and A-body guys say it hangs almost 2 inches below the crossmember.
Old Nov 3, 2010 | 11:25 PM
  #306
cutlass_455's Avatar
Ive got a LH8 pan collecting dust right now cuz it didnt fit my G body and hung too low. Dont waste your time with it. Get a pan mod'ed or get a Canton/Autokraft one.
Old Nov 4, 2010 | 10:49 AM
  #307
Old School Heavy
I just spoke with Travis at Holley about the new LS Retrofit pan that they announced at SEMA. They said that it will not be available til' sometime 1st quarter 2011. So, at this point, I am still waiting for the Mast Performance pan.
Old Nov 5, 2010 | 06:02 PM
  #308
rallystyle's Avatar
i would have to say the holly pan looks just like the lhx pan. the front looks to deep to work on a body cars. the mast pan has the shallow front to clear the tie rods. just wish they would have the mount on the back for the trans to bolt up to. i have a lh8 just sitting and had a autokraft that i sold because the headers hit the oil filter block. it is good to see some more pans on the market.
Old Nov 9, 2010 | 10:13 PM
  #309
futureuser's Avatar
Mast pan leaving a gaping hole underneath My LY6/4L80e? F*%$ing great. I guess it's between Holley and retro for my 69 Camaro.
Old Nov 26, 2010 | 11:04 PM
  #310
Schitzo's Avatar
mast oil pan
Old Nov 27, 2010 | 06:39 AM
  #311
Old School Heavy
Originally Posted by Schitzo
mast oil pan
Very tasty. Where did you find these specs?
Old Nov 27, 2010 | 10:10 AM
  #312
Schitzo's Avatar
On the Mast website. Here are the links including the PDF with the information
http://www.mastmotorsports.com/2010/...%20Pans&id=160
http://www.mastmotorsports.com/2010/..._pan_views.pdf
Old Nov 27, 2010 | 10:13 AM
  #313
Old School Heavy
Very cool. Now, if they would just make the damn thing! It is the only thing I am waiting for to put the engine in my car.
Old Nov 27, 2010 | 10:23 AM
  #314
Schitzo's Avatar
I didnt know they are not being made just yet. Maybe you can comment here
https://ls1tech.com/forums/conversio...s-oil-pan.html
Old Nov 28, 2010 | 06:10 AM
  #315
holschen's Avatar
Default the downside
with mast pan is that it still missing the bolt holes for the transmisson
with holley you have that
Old Nov 28, 2010 | 06:18 AM
  #316
Old School Heavy
This seems to be the theme with these oil pans. Each one has it's attributes, but is not perfect for everybody.
For me, the Mast is a better choice because it is lower profile at the front. This is a big deal for steering arm clearance on A-bodies. And, since I am running the old school 200-4R, I don't need any transmission bolts.
If you are running a Camaro, as listed in your signature, why not just use the JZ Motorworks pan?
http://jzmotorworks.com/LS1Pan.html
It has the trans bolt holes.
Old Dec 1, 2010 | 07:50 AM
  #317
jksstar's Avatar
anyone have the dimensions for Milodon oil pan #31083? I can't seem to find them anywhere.
Old Dec 1, 2010 | 01:55 PM
  #318
holschen's Avatar
Default oil pans
    GM pressure
    relief valve
    bypass built
    into pan-----------------YES---------------?----------------?
    oilsump
    capacity------------------?--------------5,5q---------------5q
    (with filter)---------------?--------------6,0q--------------- 5,5q
    max pan depth-----------5.75"------------5,89" --------------5,5"
    bolt to trans--------------NO-------------YES----------------YES
    AN fittings for
    remote oil
    coolers & oil
    filter--------------------YES---------------NO----------------NO
    sorry best i could do for now
    Old Dec 1, 2010 | 02:15 PM
      #319
    Old School Heavy
      GM pressure
      relief valve
      bypass built
      oilsump
      AN fittings for
      remote oil
      coolers & oil
      Wow Holschen, if you refine that a bit, it could be a sticky in the a-body section!
      Old Dec 7, 2010 | 04:05 PM
        #320
      Old School Heavy
      Default Mast Hot Rod Oil Pans are almost ready.
      Mast just posted in their Facebook that 15 pans will be done for the end of next week. When I ordered mine on the phone with Chris, he said the dipstick is not included. He said the pan uses LS3 dipsticks à la 2010 Camaro.
