LSX oil pans
Set really high, an LH8 pan may work, but it depends on what trans you are using, how it fits in the tunnel, how far forward the motor sits, and what driveline angle you can tolerate.
HX has front steering, so you are clear to the X member/sub frame. Have heard some section the X member to fit a pan. Depends on the engineer if their is one involved.
I'm looking for a pan which is only 1,8' inches deep at the front, for 13 inches. Where the red line runs through the pan above in the picture
The only thing i found is this one. It's a dry pan and will $4000 by the time i'm done.
http://www.drysump.com/ls1-2.htm
Dose anyone know the dimensions of this sump. I'm looking for something like this one as a wet setup. I guess this a dry setup?
Type in E30
Shazaam!
This has been done several times.
https://ls1tech.com/forums/conversio...-ls1-swap.html
Thanks, Jean-Marc
You need the holden pan or the cts-v pan? What holden if so?
Also John does SDparts carry PN 19212593 yet? I know its on NBO as well as the Windage tray for the LH8?
Spacer is SDLS7SPCR - $29.95 that is the only "special" part you will need. the rest is all stock style or regular LS aftermarket.
FYI as posted earlier the retro car swap that you asked about 19212593 uses the LH8 oil pan AND the windage tray. plus it comes with dipstick and bolts. good deal if you ask me
I have seen G-body swaps with modded oilpans (notch the front face of the sump), and modded frame crossmembers. Both require welding, are you good at aluminum, or steel?
