LSX oil pans
Old 03-17-2009, 02:51 PM
  #121
NemeSS's Avatar
Originally Posted by John@Scoggin
Yes, they changed pns when they went to the LSA engine.
can u plz post the part numbers for:
CTSV oil pan
windage tray
pickup tube.
LH8 pan
windage tray
pickup tube
thanks
Old 03-17-2009, 02:53 PM
  #122
beertestr's Avatar
Originally Posted by musclecity85
i have no welding skills period
Then drive over bumps carefully.. and use the LH8 pan, or crack open the wallet for either a fabricated pan, or modified F-body pan..
Old 03-17-2009, 05:31 PM
  #123
LS1Tech Sponsor
Beau@SDPC's Avatar
CTSV oil pan
windage tray
pickup tube.
LH8 pan
windage tray
pickup tube
thanks
well they are earlier in this post as a matter of fact, but you will have to be less general as the CTSV came with both the LSA and the LS2 and the LS6...
and the LH8 pan is also part of a kit that comes with the pickup, windage, bolts, tube, and dipstick. its a page back iirc. 19212593
Old 03-18-2009, 01:47 PM
  #124
NemeSS's Avatar
so thers 3 versions of the CTSV?
Old 03-18-2009, 02:02 PM
  #125
LS1Tech Sponsor
Beau@SDPC's Avatar
CTSV came with 3 diff engines. The LS6, and the LS2, but both have the same PN for the pan at the moment. they may have been diff before, but i do not know on that one. Then the LSA is a diff pan as well. So really there are only 2 pans for the CTSV. The LS2/6 and the LSA
Old 03-19-2009, 08:32 PM
  #126
musclecity85's Avatar
i was planning on running larger wheels at least 20" so hopefully clearance wont be a problem.. could someone shoot me the link to or part number to the gm LH8 pan package..thanks
Old 03-19-2009, 09:58 PM
  #127
LS1Tech Sponsor
Beau@SDPC's Avatar
there it is...go to sdparts.com and plug it in like this
http://www.sdparts.com/product/19212593/FPANKIT.aspx
and you go from there...or you can call in. either way.
Old 04-08-2009, 01:15 AM
  #128
jdub808's Avatar
Default oil pan for a ls2 into a 65 impala
So I read everything in this post and now Im more confused. LH8 , CTSV , S&P? Im dropping a ls2 into my 65 Impala and the car will be lowered a bit not to the ground but lower. Is the LH8 going to hit? Would the CTSV fit and fit better or should I go the S&P route?
Thanks
Old 04-08-2009, 09:03 AM
  #129
LS1Tech Sponsor
Beau@SDPC's Avatar
People normally either go LH8 or Fbody pan.
Old 04-08-2009, 05:18 PM
  #130
jdub808's Avatar
Default f body pan
If use the f body pan isnt that after I send it out to be modified? I know S&P cant use my C6 pan so they told me I had to locate a f body pan then send it out to them for welding.
I would love to be able to use the LH8 set up but am worried it will pound the ground if I hit road bumps.
Old 04-08-2009, 08:02 PM
  #131
philntx's Avatar
The LH8 pan is about 7.5" from the flange to the bottom of the pan.
The LS2 Corvette is about 5"
The F-Body is a little more than 5"
Old 04-09-2009, 12:38 AM
  #132
jdub808's Avatar
I guess that 2.5 inches will makes a huge difference cause it seems everyone's affraid of bottoming out on it.
Old 04-12-2009, 09:00 PM
  #133
ls6_rx7's Avatar
Default oil pans
I currentlly have a flared c5 oil pan on my ls6. For my swap into my rx7 using(hinsonsupercars subframe) i need the ls1 style pan. I found one on ebay for a decent price but it has a terrible description and the partnumber it has shows it as the ls2 one up there however the pics of it looks like one of the other models up top on this page. Will the bolt holes match up with the pattern on my block? And sealing aswell?
Old 04-12-2009, 09:01 PM
  #134
ls6_rx7's Avatar
2007 Truck 4.8, 5.3, 6.0, 6.2 with Filter
that is what the one i found looks like but the partnumber is the ls2 style.
Old 04-30-2009, 11:15 AM
  #135
serpentnoir's Avatar
Default ARE pan #1004
Does anyone know how deep this pan is at the front (not where the scavenge fittings are) ?
Old 05-18-2009, 04:17 PM
  #136
fasteddy51's Avatar
Default F-Body Oil Pan Part #'s and Prices
Several swaps need the F-Body oil pans, and it seems they are fairly hard to come by, and the prices tend to be relatively high when you do find them. Currently on GMpartsdirect.com the prices are: the oil pan (12558762) $177.00, windage tray (2558253) $15.87 and oil pickup (12558251) $30.04. The three pieces can be obtained for a total of $222.91 new. If you know someone at the local dealership, they can usually order them for about the same pricing, sometimes even better. Anyway, the more I have searched for the three components for my conversion, I may just go ahead and buy new for what little the price difference can be at times for used parts. Just an FYI.
Old 05-18-2009, 05:02 PM
  #137
JasonWW's Avatar
I bought a new F-bidy pan about a year ago and I wanted to mention that it does not accept the regular oil filter. It was changed to a newer style filter that is the same size, but has a different thread.
Old 05-18-2009, 11:21 PM
  #138
rsz288's Avatar
Yes it has a different thread as it has an internal by pass valve vs older style having in pan bypass. PF48.
Old 06-04-2009, 11:51 AM
  #139
bad98t/a's Avatar
I dont know if anyone else is doing an LSx swap in an s10 or blazer, but someone told me you could use an 08 hummer h3 5.3 pan and there would be no mods to the crossmember or oilpan. Anybody confirm? Thanks
Old 06-04-2009, 12:19 PM
  #140
LS1Tech Sponsor
Beau@SDPC's Avatar
using that pan i believe you will still need to notch the k member.
Quick Reply: LSX oil pans
