Help with PVC system
Old Jan 13, 2008 | 06:11 PM
71chevellels1's Avatar
Default Help with PVC system
Can i just block off the vent tube from the TB to the valve cover? How about the crossover tube? What do i have to block off for the swap? its a ls1 into a 71 chevelle? What bout the line connected to the motor under the tb i think its vaccume.
Heres a link to the things im talking about.
http://www.ls1howto.com/howto/geniii...kpcvsystem.jpg
Old Jan 13, 2008 | 07:46 PM
Schwanke Engines's Avatar
LS1TECH Sponsor
You can eliminate all the hoses and just run a carb type fuel filter out of one of the vents on the valve covers if you want. Put plugs on the rest of the holes. The PCV system is used to capture any emmisions escaping out of the crankcase. It really won't effect power leaving it hooked up, but it is not very nice looking. All you need is a filtered vent so the crankcase can breath. If you seal it up completely, you will begin to see oil leaks from your seals due to pressure build up in the crankcase.
Old Jan 15, 2008 | 08:23 PM
Shawn MacAnanny's Avatar
Not to hijack the thread but i dont need to hook a vac line to a breather in the valve covers?
Old Jan 16, 2008 | 08:53 AM
LS1MCSS's Avatar
Do it this way.
Old Jan 16, 2008 | 06:22 PM
Wow thats a really nice setup I like how you mounted the coil packs im definately going to do that.
Old Jan 17, 2008 | 09:24 AM
LS240sx's Avatar
MCSS what catch can is that. Ive been looking for a small one I can mount on that head for a decent price.
Old Jan 17, 2008 | 01:49 PM
leonpiper69's Avatar
catch can just looks like a water seporater for a compressor. the type with the little twist style petcock on the bottom.
Old Jan 28, 2008 | 03:27 PM
chevroletfreak's Avatar
How is the driver side vented?
