Ls1 into a 300ZX. What will I need??
Old 02-25-2008, 10:58 AM
mustang93's Avatar
Default Ls1 into a 300ZX. What will I need??
OOOK. Im doing an LS6 into a 300Zx for a customer. We are also Doing a Single turbo steup on the this same car.I have done many crazy swaps. I have done searches and nothing tells me what I will need to make it fit. What mounts? Will anything need to be cut/Welded? ETc. Im needing some good advise and info on this swap. Thanks for all your help.
Old 02-25-2008, 12:20 PM
mustang93's Avatar
Old 02-25-2008, 01:40 PM
sciff5's Avatar
As far as I know I dont think there are mounts currently available to put an ls in a 300zx. You would most likely need to fabricate your own..
I do know of a guy locally who put one in a 300zx so it should fit fine. I think he is still on stock exhaust manifolds though.. putting a turbo in there will deff require a little more work than just the stock ls6
Old 02-25-2008, 03:27 PM
mustang93's Avatar
I have seen it done ETc. But need to know if I need a different oil pan, Etc.
Old 02-25-2008, 07:31 PM
mustang93's Avatar
Old 02-25-2008, 07:38 PM
2000_SS's Avatar
i'm sure it's been done, but i've never seen/heard of a 300ZX with a LSx in it....i bet it will be wicked.
as far as what you need:
1. (1) Nissan 300ZX
2. (1) GM LSx Engine w/harness & ECU
3. (???) a lot of tools, time, and patience
a buddy of mine had a Z for a while, we could barely put a water pump on it, much less attempt a motor swap
good luck, sorry for no help, make sure to keep us posted on this build
Old 02-25-2008, 08:36 PM
mustang93's Avatar
Will do.. I have done a TT motor swap on a few but never put an LSx motor in it. But I guess Ill figure it out.
Old 02-25-2008, 09:01 PM
janaka's Avatar
www.hybridz.org
i'm a member there... i have a '76 with an LS1 going in next month
Old 02-25-2008, 09:34 PM
Moderator
91parkave's Avatar
theres a 300z on streetfire with a ls1, as for details......
Old 02-25-2008, 10:07 PM
Yellowbrother's Avatar
z32 or z31??? on z32...
depending on wat u wanna do...if u want to line the shifter to where the stock shifter was...u have to cut firewall and into the tranny tunnel...alot of it too...i'm using camaro oil pan with the t56....the tranny mount is dependent on ur creativity....the motor mount u can use the s&p style adapter plate and energy suspension rubber mount and build it from there....it will line everything up close enuff to build the most direct mount as possible to the stock location....
Old 02-25-2008, 10:27 PM
mustang93's Avatar
Hummm.. I think we are going with a Th350 trans so The shifter mounting wont be an issue. Where do I look for the S&p style adapter?
Old 02-25-2008, 10:36 PM
ebay.....
Old 02-25-2008, 10:37 PM
btw i'm going with stock n/a radiator with ford taurus fan....
Old 02-25-2008, 11:46 PM
mustang93's Avatar
Thanks for the info.. KEEP IT COMING!
Old 02-26-2008, 01:23 AM
xXxSilveradoxXx's Avatar
Where you located? I'm currently installing a Twin Turbo, Dry-Sumped, LQ4 with nitrous into my 1990 300ZX. If you are close enough to my I'd be happy to come over and give you some advice and some help.
Old 02-26-2008, 01:54 AM
chuntington101's Avatar
there is a sweed on here that did this conversion (without the turbo though) do a search and see if you can find the thread.
Chris.
Old 02-26-2008, 01:55 AM
we need more info on this build!!
Old 02-26-2008, 10:04 AM
mustang93's Avatar
^^ HECK YAH!! I live all the way in Texas..
Old 02-26-2008, 01:23 PM
Here is a couple Pre-Op pics, I'll post up some more later today when I'm on my other computer. It was a little dirty but it's got a strait body.
Old 02-26-2008, 04:38 PM
nothing else to add really...once u cut the firewall and tranny tunnel...and build the mount...everything is like any other lsx swap...
Quick Reply: Ls1 into a 300ZX. What will I need??
