Questions on fuel system
Old Mar 4, 2008 | 06:25 PM
Grewe02's Avatar
Default Questions on fuel system
Hey guys, I'm stumped on the fuel pressure regulator. From reading search threads, the stock one in most F-body vehicles is in the tank. I was pretty sure it was on the fuel rail? If not, WTF is on the fuel rail?
My motor is a 98 out of a Trans Am if that helps... Just trying to figure out what all I need to make my motor run once it's installed.
Thanks,
Old Mar 4, 2008 | 06:32 PM
cherryelky305's Avatar
i believe thats just a small regulator to regulate between the 2 fuel rails. nothing more, just makes sure that each bank has even pressure.
Old Mar 4, 2008 | 07:25 PM
67rsss's Avatar
I believe it is called a pulse regulator or damper, it helps to even out the pressure at the rail since it is dead-head.
Old Mar 4, 2008 | 08:20 PM
oange ss's Avatar
pulse dampner, dampens fuel pressure fluctuations caused by the pressure regulator being so far from the fuel rail
Old Mar 4, 2008 | 09:48 PM
Grewe02's Avatar
Good deal. So would a stock one be sufficient? At the moment my motor is making ~500 HP.
Old Mar 4, 2008 | 10:15 PM
ls1nova71's Avatar
Most people just use a 99-02, I believe, Corvette filter that has the regulator built in. I would thnk that would be suffecient for your application.
Old Mar 4, 2008 | 10:43 PM
m8w6r77's Avatar
the fuel filter from 01 corvette has the regulator in it. just like ls1nova71 was saying
Old Mar 5, 2008 | 02:51 AM
Grewe02's Avatar
Fuel filter, hmm? And this mounts to the fuel rail? In the tank? Or on the frame rail? I'm getting one hell of a confusing picture from the intarwebs
http://www.innerauto.com/browse/year...te+Fuel+Filter
Old Mar 5, 2008 | 07:59 AM
SheldonZ28's Avatar
It mounts outside of the fuel rail, normally under the car.
In my thirdgen swap, ill be mounting mine just underneath the rear seats, then running a single fuel line to the front of the car.
Old Mar 5, 2008 | 08:17 AM
Stu Cool's Avatar
It's easiest to mount the filter regulator as close to the pump and tank as possible. That way you can run a single line forward. What type of pump are you using? External or in tank?
Pat
Old Mar 5, 2008 | 09:26 AM
ls1nova71's Avatar
Check this out, it might help. https://ls1tech.com/forums/showthread.php?t=246157out.
Old Mar 5, 2008 | 09:51 AM
Grewe02's Avatar
Pat
I'm using my stock intank pump complimented by an inline Walbro 255.
So this is the one and only fuel like that goes to / from the motor? No return from the fuel rail, correct??
Originally Posted by ls1nova71
Very awesome, thanks.
Old Mar 5, 2008 | 10:02 AM
SheldonZ28's Avatar
Yes, after the filter/reg, there is a single line that runs up the car to the fuel rails.
Old Mar 6, 2008 | 08:27 AM
Grewe02's Avatar
Outstanding. You just reduced my headache by about half.
