Colorado Swap
Old Jun 15, 2008 | 09:52 AM
bad5.0's Avatar
Default Colorado Swap
Im doing a biult 5.3 into an 05 4 door Z-71 Colorado. Any tips would be great. I have the motor done, just got a truck intake, and working on a deal for the acces drive. Motor mounts are done. All I need is the trans bell housing and input shaft I think. I think i have the PCM harness ready as well.
Anybody know if someone makes the headers for this swap or am i going to have to fab them up?
Old Jun 15, 2008 | 09:06 PM
E36LUVA's Avatar
Talk to this guy.
https://ls1tech.com/forums/showthrea...light=colorado
Old Jun 16, 2008 | 07:57 AM
Jonce's Avatar
Check out http://www.currentperformance.com/ for the headers and other accessories.
Old Jun 16, 2008 | 08:14 AM
bad5.0's Avatar
Thanks for the info guys. I have been talking to Current Performance and thay are going to do my harness and pcm tuning. Kind of high on price though.
Old Jun 16, 2008 | 10:49 PM
philntx's Avatar
Price is relative to the size of your headaches you are willing to endure by doing one yourself.
Old Jun 16, 2008 | 10:50 PM
krazy4's Avatar
My friend wants to do this so bad it isn't even funny.
Can't wait to see how this goes.
Good luck with the project!
Old Jun 16, 2008 | 11:07 PM
snketr's Avatar
What accessories are you using? I'm picking up an LS1 this weekend for my RCSB 04 Colorado.
Old Jun 17, 2008 | 06:36 AM
01WS6/tamu's Avatar
Whatever happened with the V8 colorado the general kept talking about. Or is it another bait us and then forget who buys your cars kinds of deal that gm is famous for.
Old Jun 17, 2008 | 06:55 AM
bad5.0's Avatar
Default i know
Your right. Its just more than i thouhg it would be. I looked at the painless wiring kits with computer and cam already tuned for the same price though. I will see when in get to that point what i want to do.
Old Jun 17, 2008 | 07:04 AM
01WS6/tamu's Avatar
Both Phil and I have built v8 s10's, for some the wiring is definitely the stubling block for their project. I chose to build my own but have alldata at the shop and lots of experience with harness' so for me it was not biggy I do suggest buying one if you are even remotely uncomfortable with wiring.
Old Jun 17, 2008 | 07:08 AM
bad5.0's Avatar
I am running a 5.3 acces drive from a truck and a 6.0 intake and injectors. Ya im not reayl big on wiring. I am an enigne biulder and have my own shop but hate doing wiring, lol. Ifs its plug and play then its not a problem or even the Painless lits because they are all labled realy nice.
Old Jun 17, 2008 | 09:16 AM
snketr's Avatar
The truck accessories and pulleys fit? I was under the impression they didn't b/c they stuck out to far?
Old Jun 17, 2008 | 11:08 PM
350SS's Avatar
why do you need a different bellhousing and input shaft?
Old Jun 17, 2008 | 11:17 PM
snketr's Avatar
Input shaft is different splines ( I think) and bellhousing bolt pattern is different.
Old Jun 18, 2008 | 09:51 AM
bad5.0's Avatar
Default yep
that is correct.
Old Jun 18, 2008 | 02:12 PM
350SS's Avatar
This is a 4l60, correct? And it was behind the 5 cyl or 4? Just curious.
Old Jun 18, 2008 | 06:38 PM
bad5.0's Avatar
it is a 4l60e abd it was behind a 5cyl. i am rebiulding it anyway so the bell housing and input is no big deal.
Old Jun 18, 2008 | 06:57 PM
350SS's Avatar
sounds good, learned something new
Old Jun 18, 2008 | 10:06 PM
ls1blazer's Avatar
The harness will be the best money you spend. Especially when your trying to make late model electronics mate up so all your gauges work right. Certain pcm/programs will only work with the gauges and engine/trans combos . Unless your converting to a cable throttle , DBW tb and pedal can become a big issue as well. 24 or 58 tooth reluctor ring becomes an issue as well .
I made my headers and had them coated.
Old Jun 19, 2008 | 07:58 AM
bad5.0's Avatar
Ya i know, and i will be going with current. It just sucks that the harness and tune will cost me more than the engine biuld or tranny biuld, lol.
