Who Offers A Water Pump Stud Kit?
Old 07-05-2008, 12:32 PM
LS1GMCTruck's Avatar
Question Who Offers A Water Pump Stud Kit?
ARP doesn't seem to offer a water pump stud kit for an LS1. Who does? Thanks
Old 07-05-2008, 01:45 PM
98blackSS's Avatar
Why would you need that?
Old 07-05-2008, 02:29 PM
For the same reasons my heads, exhaust, etc., are studed...superior torque capability & control and load distribution, ease of installation/removal with positive alignment, and much less aluminum block thread damage, which I'm beginning to experience. Have a clue who makes them?
Old 07-05-2008, 03:01 PM
98blackSS's Avatar
Interesting.. You're the first I've ever seen looking for them honestly. In all the LS motors I've done over the years with countless WP removal/installations, it's never even crossed my mind. What kind of block damage are you experiencing exactly? Not sure I understand the head and exhaust analogy in this particular example, but whatever works best for you.
Old 07-06-2008, 06:20 PM
stevieturbo's Avatar
Its only a water pump....just how tight do you think those small bolts need to be ???
If the threads get damaged, its entirely the builders fault. And that isnt something that would happen easily !!!! They really dont need to be tight at all.
Old 07-06-2008, 08:37 PM
Its a habit of mine, using studs when possible in aluminum blocks. I get it from being in the Mercury Hi-Performance V-6 Outboard & marine manufacturing business for 25+ years. Its a service/durability thing. There aren't very many of them that hold the pump on, guess I'll just measure what I need & buy them from my stainless fastener sources....Thanks
Old 07-06-2008, 11:05 PM
Lilscottie's Avatar
In my ARP catalog. They've got bolt kits, no studs:
GM III/LS Series small block water pump bolts with thermostat housing bolts
Black Oxide:
Hex: 134-3201
12-Point: 134-3202
Stainless 300:
Hex: 434-3201
12-Point: 434-3202
Hope this helps.
It is better to be safe than sorry fellas.
Old 07-07-2008, 10:23 PM
JxxxOxxxE's Avatar
I can see why you would want these...I've had one or 2 bolts break while removing the water pump before. Drilling them out is no fun....I upgraded to ARP stainless bolts, but never thought about doing studs. Seems like there might be come clearance issues between the radiator, and the studs, for getting the pump on...
Old 07-08-2008, 12:40 AM
Ackattack1's Avatar
Can you go to a bolt supply place and get some all thread and make your own?
I just wonder if you'll run into problems with a belt running close to them. Not real sure where the belt is in respect to the bolts, just something to look at.
Old 07-08-2008, 04:59 PM
98blackSS's Avatar
Unless those bolts were way over torqued when installed, I can't see any logical reason for them breaking.
11ft/lb first pass and then 22ft/lb on install. It's not much.. Leave the impact gun on the work bench guys.. damn
And if you can't thread the bolts in all the way by hand, stop and clean out the threads.
Old 07-12-2008, 04:34 PM
TJ
TJ's Avatar
if it doesnt hit a bolt head, it shouldnt hit a nut on the end of a correct length stud.
Old 07-12-2008, 05:32 PM
Stu Cool's Avatar
Also remember to use anti-sieze when putting any bolt, or stud, into aluminum.
Pat
Old 09-29-2008, 10:51 PM
loweredd's Avatar
I've got studs in mine. They came with the Synister serpentine kit. They were a little too short for the threaded standoffs I have to screw onto them. I am going to make some new ones with metric allthread. They are an M8x1.25. The ones I have are like 95mm and 105mm, but need about 120mm, so I will just cut some new ones.
Old 09-30-2008, 09:54 AM
exodus's Avatar
all thread works, but is a little on the soft/flimsy side. I know this will sound retarded, but go walk down the hardware isle at home depot or lowes, and you might get lucky. They have a lot of grade 8 stuff too.
Old 09-30-2008, 10:06 AM
loweredd's Avatar
Stainless shouldn't be THAT soft, I wouldn't think....
Old 09-30-2008, 10:21 AM
exodus's Avatar
not sayin the studs that came with your kit are soft, the allthread though is another story. Atleast what I have seen anyway. What is the size you would need diameter wise?
Old 09-30-2008, 10:26 AM
loweredd's Avatar
I don't know what the studs in the kit are, but they are actually studs instead of cut allthread. They aren't stainless though. The allthread that the fastener place has is stainless.
The thread is M8x1.25. I need about 4.75 inches. When they measured for these studs, they must not have bottomed the stud in the block, cause they are about an inch short. I've seen a couple guys say that they stripped out thier standoffs for the brackets just by threading them by hand, and now I think I know why. They probably only had about 1 thread in the aluminum standoff.
Old 09-30-2008, 10:38 AM
exodus's Avatar
AH, now i get it, I was under the impression that it was the supplied studs that were the stainless ones. That would work then. Just have to make them long enough to get as much bite as possible in the block so they dont pull out, especially if there is slight carnage already.
Old 09-30-2008, 01:32 PM
Personally...I would not use all-thread. I would use stainless rod & cut my own threads. But thats just me.
Old 09-30-2008, 07:25 PM
TJ
TJ's Avatar
i will agree unless the rod is higher quality than 18-8. its a lil soft and holding the front of a kit on, id be against it myself.
just me though. it will be more than suffice in most cases except mine. i get the shaft most of the time.
Quick Reply: Who Offers A Water Pump Stud Kit?
