Any body use Current Performance Wiring?
Jason, what's your project that you are waiting for this "bargain" harness for?
If you are it should be Leonard Sparks, he runs the Chevy Thunder web site. I've known him through the internet for more then 10 years and always seemed like an above the board kind of guy. He has a bunch of swap info on his site. I think he still does the harnesses as a side line, so he doesn't have as much overhead, as guys like Jared do, that do this for a living. The first question I always ask is if they harness follows the factory color code. If it doesn't it makes it harder for outsiders to trouble shoot. They can save about 50% of the wire cost by using nonstandard, non-striped wiring. The next question is are all the connectors new. Connectors like the PCM connector, wouldn't bother me if they were reused, since all the contacts would be replaced anyway, but the plastic connectors age and get brittle, so even if you replaced the contacts, the latch could still break and come loose. Also some guys tape wrap the harness instead of using loom, which is another cost savings. Personally I prefer a tape wrapped harness in an old car since it seems more original. Others don't have any mounting clips to support the harness, all things that add money to the cost. By the way I just looked, Chevy_Tpi has 2 auctions on Ebay, for harnesses, each of them for $400, that doesn't sound scary cheap to me. Its not like they're plug and play modified harnesses, to fit something late model, they stand alone harnesses, with no emissions, of course he is throwing in a programmed PCM, but that's the smart thing to do, since it alleviates a lot of other issues.
Why did you not use the Current Performance Harness you have Crowder?
https://ls1tech.com/forums/showthrea...560&highlight=
Its a good price... I would buy it, but the main harness length to the ECU is not long enough for my build....maybe it will work for you....
