Convertible Vehicles Enthusiasts | Information | Maintenance
widest wheel/tire combo on a vert
Old Jan 31, 2006 | 12:59 AM
sprung_monkey's Avatar
Default widest wheel/tire combo on a vert
ok guys i am haveing some problems with tires right now
i havd an 18x10 wheel in the back but i keep getting told that only a 285/35/18 or an 295/35/18
but im wanting to put like a 305 on the back can anyone help me out on this?
Old Jan 31, 2006 | 09:31 AM
quiet_storm98's Avatar
i know someone that put 315's on his 10.5 inch Z06 wheels however i know it isn't recommended to do that because 315's are supposed to be mounted on 11 inch rims but i guess 305's would work
Old Feb 1, 2006 | 12:29 PM
Jimmyz's Avatar
I have 315's (Nitto DR's) on a 9.5" wheel and it looks fine and no its not "correct" but works with no issue whatsoever.
However...the correct size wheel for a 315 is 10.5"'s wide.
Old Feb 4, 2006 | 09:34 AM
shadow's Avatar
Might want to watch out ? The **** says he "isn't going to put up with" these kinds of comments
Seriously, it depends on the Mfg of the tire. In any event, I've got 315's on my 11"ZR1 (5 spokes) and they fit fine. Have used Michelins, Khumos' and a couple other brands with no adverse actions.
Old Feb 9, 2006 | 02:35 PM
Xsta Z 28's Avatar
Thumbs down
Nice way to talk about a Moderator . . .
Old Feb 9, 2006 | 04:48 PM
Sam 04 GTO's Avatar
I had 315's on 17x10 wheels on my 98 TA with minor rubbing on the inner fender, nothing the hammer didn't fix tho.
I plan on putting 315's on my 01 'vert, I don't see it being an issue.
Old Feb 11, 2006 | 10:37 AM
00ultraz28's Avatar
I've got 315s on a 9.5inch wheel also. It looks good i think and i haven't had any problems other than a little tire rub.
Old Feb 21, 2006 | 05:32 PM
tkta02's Avatar
18X9 Front and 18X10 Rear with the Nitto DRII 305/35-18. I installed a full SLP Level 1 Suspension so its slightly lowered. I have slight rubbing on the inner fender well at the top on hard turns. Im in the process of finding a shop to roll my inner fender well slightly so I dont destroy my tires or crack the paint on my fender lip when rolling it.
The perfect rear tire size is 295, but Nitto doesnt make a 295 DR in 18"
My Luck...
Attached Thumbnails widest wheel/tire combo on a vert-smallta.jpg
Old Feb 21, 2006 | 09:45 PM
676998Camaro's Avatar
Do our verts have a different rear wheel well than the coupes? I was thinking about doing the 17x11 ZR1s with the 315 tires if they fit.
Old Feb 22, 2006 | 08:19 PM
stroke it's Avatar
i have 305/30/19s on the rear of my car with a 19x11 wheel
Old Feb 22, 2006 | 11:36 PM
9silverbird8's Avatar
295s max eh? Im running 335s on 17x11 ZR1s. A little rubbing on hard corners and steep driveways, but not enough to really concern me. Look here:
https://ls1tech.com/forums/wheels-tires/319417-check-out-black-zr1-s-335s.html
Old Feb 23, 2006 | 04:21 PM
tkta02's Avatar
9silverbird8: Im going to assume your reply post was to me. If it wasnt to me, disregard this post.
Nowhere did I say 295's Max would fit. I did say I have 305's and they rub slightly and 295's would be perfect. I also mentioned my car has a suspension and unlike you... im running 18's not 17's. Do you think Maybe?!?! that has something to do with my situation.
Your post just makes me laugh.
Good-day!
Old Mar 27, 2006 | 10:48 AM
HASTINGSRJ's Avatar
I run 285's out back...had to do a little massaging to the innner fender wells though to get them to fit
Old Mar 27, 2006 | 12:33 PM
Jimmyz's Avatar
315's on a 9.5 inch wheel no rubbing issues at all.
Old Apr 6, 2006 | 09:47 AM
HASTINGSRJ's Avatar
Jimmyz, you got any pics that you can post of them????
Old Apr 6, 2006 | 09:55 AM
Jimmyz's Avatar
I can send you pics if you get me an email address? : )
Old Apr 6, 2006 | 10:02 AM
HASTINGSRJ's Avatar
robert.hastings@usmc.mil
Figures, I just ordered another set of 285's for mine...I am getting them put on today:
Old Apr 19, 2006 | 12:41 AM
98blackvert's Avatar
i got 275's all 4 and they fit perfect
