16 salad shooter for ET Streets
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
Will a set of salad shooter 16 inch rims off a 95 camaro bolt on a 03 Z06.I need some cheap wheels for ET Streets.They will be for track use only and I don't care about looks.Thanks
7 Second Club
Re: 16 salad shooter for ET Streets
Well it does'nt look like I'll be using them.There is no way I'm taking a grinder to my 250 mile,5 day old car.The SS in my sig saw some work with a grinder on the calipers but the Z is off limits. Anyone know of a lightweight 16 inch wheel that will fit without hacking my ride.
John @ CCW said he had a Wheel That would work without Grinding he said it was not for the high HP guy but probably perfect for the Z06 But If you just want the back don't tell him they are for et streets because he told me he could only sell them as a set for insurance reason. If you need the number PM me.
7 Second Club
J-Rod I took your advice via PM and did the grinder mod.I used SLP V-6 Firebird takeoff wheels and they fit just fine.Actually I took off less than you did and touched it up by hand with sandpaper.It was much less hacketry than I initially thought.
you could have put 17" wagon wheels and run drag radials and not grinded anything. Im sorry but I cant put a grinder to my 40K car.
7 Second Club
