CARTEK C6 Stage 1 Twin Turbo dyno results.
Here are the preliminary dyno numbers on our C6 Stage 1 Twin Turbo system. This is on 92 octane, cats and full exhaust, 3.42 gears, stock cam. I'll should have some pictures of the completed system in the next few days along with some track runs, weather permitting.
It literally idles (thanks to the stock cam) drives and sounds like a bone stock C6 and probably is a bit quieter because of the turbos, until you go WOT. LOL
Our Stage 2 Twin Turbo system will also run on pump gas and it should be in the 650+ RWHP range.
![](http://www.cartek.net/images/cartekttstage1.jpg)
Julio
Julio
Update on the power, this is same as above but with out cats and more boost. Still using the stock mufflers and pump gas. The boost controller that we temporarily used surges at 3600 rpm (causing a surge on the torque curve below 4000 rpm) but is at 9.3 psi at peak power 5950 rpm.
Julio
Julio
![](http://www.cartek.net/images/cartekttstage1_2.jpg)
Originally Posted by SSPEEDY
Wow!!!
How much boost were you running on the first dyno?
as usual, great numbers from a great company!
Thanks for the props SSPEEDY.
On the first dyno sheet the boost was at 6 psi with cats.
Julio
Julio
Julio
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I can't wait to see the final numbers when it is all done.
