Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
cam selection
Old Apr 9, 2006 | 12:43 AM
c5_ls1_6spd's Avatar
Default cam selection
what cam should i go with to get about 30-40 more rwhp?
Old Apr 9, 2006 | 12:48 AM
LS183G's Avatar
What all mods are done to the car now, and do you know what future mods your planning on?
Old Apr 9, 2006 | 12:59 AM
2.73 Vette's Avatar
Too easy..
TR 224/224 .563 112 LSA.....The most tried, true and proven cam of any on the market..
This cam delivers 35-50 rwhp on a bone stock engine.
I personaly gained 5 mph through the 1/4 mile with this cam over my stock LS1 cam in my 2004 automatic C5 coupe. A 5 mph gain through the 1/4 mile with 2.73 gears has to be a minimum of a 40 rwhp gain with the cam alone.
.....Averages....
Stock C5.......290-300 rwhp
TR224/224 cam....325-350 rwhp
This was by far the best mod I ever did. I picked up more mph from just the 224/224 cam than I did from the 2002 LS6 heads and cam set up I had prior.
And this cam is very streetable.
Old Apr 9, 2006 | 10:31 AM
zo6vetteman2003's Avatar
Originally Posted by 2.73 Vette
Too easy..
.....Averages....
I agree, this cam is a very common selection in also a 114lsa.
Old Apr 9, 2006 | 10:53 AM
Sigforty's Avatar
Futral cams like the F13 are also very popular. I personally am running a F14 in my Z06.
Old Apr 9, 2006 | 03:02 PM
i have full boltons right now. im just wanting to get to the 400rwhp mark....
i was either thinking of going with a 224/228 .581/.581 on a 114LSA..
i might have to look into a 224/224 also.
Old Apr 9, 2006 | 04:21 PM
whats the difference (powerwise & soundwise) between a 112 and 114LSA?
Old Apr 9, 2006 | 04:26 PM
2MuchRiceMakesMeSick's Avatar
G5X3 or F13
112 will have more of a lopey sound to it and will come into power sooner
Old Apr 9, 2006 | 06:20 PM
Steve01SS's Avatar
Buddy of mine has an 01 6 speed C5 coupe. Headers, vararam, catback and a 224/228 581/588 cam put down 385 rwhp with a good tune. It's got a lope to it, but drivability is like stock.
Old Apr 9, 2006 | 09:30 PM
LTZ PLY's Avatar
My first round of mods on my 00 FRC was Kooks 1-3/4" longtubes w/ Hi-Flo cats, Vararam, Borla Stingers, 3.73 Gears, ASP Pulley, and 228/.581/114 Comps Cam. I dynoed 383 horse @ SpeedInc....and started out with a baseline of 315-320ish. Actually, Speed Inc just did the cam, header, gears, and pulley. I already had the Vararam and stingers on the car for the baseline pull. Hope this helps.
P.S. My cam will be for sale in about two weeks...I'm going with an ECS Novi 2000 and will be using there own custom grind cam. Actually, this is a good example of knowing where your headed in performance mods. I had no idea I would go the supercharger route when I had my 228 installed. It's too aggresive for the supercharger I'm told. Good luck with whatever you select!!
Old Apr 9, 2006 | 10:41 PM
PurpleHaze98's Avatar
go big thats all i can say, i went w/a 224/ .566 on both ends w/a 112lsa and i wish i woulda went bigger from day one, i think i will run this cam into the ground because it runs good but maybe just maybe ill jump up to the 230-ish area and .588 and up but i dont think that will happen for a while i guess im just gonna keep pokin and proding this 100k stock block until it goes.
Old Apr 10, 2006 | 11:02 PM
marcus769's Avatar
Too easy..
How much bigger can you go before you run into driveability issues?
When replacing just the cam, should you go through the heads too? Is a spring upgrade mandatory for a cam such as the one you talked about?
Thanks!
Old Apr 11, 2006 | 06:10 AM
2.73 Vette's Avatar
Yea youll need 918 springs and might as well put in some malloy pushrods as well while your at it..
Lots of people say so and so is very streetable..But realistically i think the 224/224 cam is the biggest I would want to go..The idle can sometimes be ruff with this cam and it has died on me once while driving it up to a stop sighn....
As far as power i just dynoed on a dyno jet today...
-stock 2002 ls6 heads
-TR224/224 .563 at 112 cam
-vararam air intake
-no cats
-Borla straight pipe exhaust
-160 thermostat
I put down 378 rwhp and 370 rwt SAE corrected and 100% smoothed vrs my 299 rwhp and 309 rwt bone stock on the same dyno....
Even if you do every thing at the most possible rwhp gain..
ls6 heads....20 rwhp
no cats......10 rwhp
exhast.......10 rwhp
air intake....10 rwhp
That would still mean I gained a minimum of 28 rwhp from this cam.....
But realistically I think I gained.....
LS6 heads......15 rwhp
no cats..........7 rwhp
exhaust.........6 rwhp
air intake.......7 rwhp ( actually have the before and after dyno with the vararam)
35 rwhp is my guess from those mods alone meaning I gained roughly....44 rwhp IMHO....
So between 28-44 rwhp was my gain...And im thinking 44 rwhp unless all my other mods just had freakish results.
Old Apr 11, 2006 | 12:43 PM
serendipity's Avatar
I'll be putting a Futral F13 cam in my C6 the first week in May. I'll post up some sound clips and dyno charts when I get her back.
Mods will be F13 cam, AFR dual springs, FAST LSX intake manifold, Callaway Honker, LG Pro longtubes with no cats, and B&B Route 66 catback. All on a dyno tune from Jeff Creech.
Any guesses on numbers? I'm hoping for 440ish whp.
