Best year for C5?
I would go 2002+ I have a 03 Z06 that I got for 33,000 with 16k on it *i know thats out of your range but shows whats out there*
Check MSN on used cars for the Corvette and then on the side bar put the compare across the years option. It will give a brief summary of updates for each year when you press on the year model.
My engine has zero piston slap and does not burn any oil at all, even when I've gone 9k between changes I did not need to add any oil!
I don't really think the oil consumption is a year model thing I think it is more of how many miles the engine has on it.
My Z28 drank oil until it hit 30k then it dropped to only burning half a quart every 5k miles then it simply stopped all together when it hit about 45-50k.
I mean after the engine is worn in it seems to run a lot more smoothly.
Jon
Jon
Ok thanks. I have always thought a hard top meant the top was removable.
2002 is the best, '99 or '01 would be second choice. Choose these years before '97, '98, 2000, '03, '04
2003-2004 are a PITA if you ever heavily mod. They had a different fuel system, which you have to change out to an earlier style for high HP, FI applications.
99 is the best of the early models, first year w/ heads-up. But all pre-2000 come with ugly wagon wheels.
2000 is a very quirky model year, avoid it. Pre-cats.
1997, 1998 are also not very desireable. Early problems not yet worked out, and no heads-up display.
It's amazing how you FRC guys go nuts over them. Especially since they were considered the bare bones, econo, gotta have a Corvette but I can't afford one.
They are the same cars as the convertibles except instead of a retractable top they have a piece of plastic covering the cockpit.
They weigh less than a coupe but have a lower top speed due to the coupe's better aerodynamics (they start to buffet like my convertible did, even the Z06 has a lower top speed but that is also due to the gearing). They also always have the M6 which is cool plus the suspension stuff.
"New for 1999
The fifth-generation Corvette added a convertible last year, and for 1999 Chevrolet's premier sports car gains yet another new trim. The introduction of the 1999 Hardtop brings the first fixed-roof 'Vette to market since 1967, offering the performance of the other trims for a lower base price. An available Active Handling System and Heads-Up Display are also new for 1999. "
It is only $500 less but if they come with the Z51 standard that might explain the difference.
http://autos.msn.com/research/vip/Sp...ette&trimid=-1
