What mods needed to run with t-66 supra???
For your C5 from a roll, you'd need that kind of power. Since a roll negates launch. So, 500HP would be a stroker, or a turbo kit, or a blower.
If you dont want to run nitrous or F.I. then definatly go with a heads/cam package, maybe do a slight overbore (it'll take it to 364 CID, which is the same size as the Vortec 6000 truck engines) up the compression, run race gas, do full exhaust, possibly gears, and definatly a clutch to handle the new amount of power. And you should be able to pull him hard off the line, and stay ahead of him imo w/ most of those. If not, go w/ a bigger engine like a 414 LS1, and do a heads/cam package, and then most of the other stuff, and you should be able to take him.
Greg
also, remember that a Supra is geared for high speed runs...
There is a guy here in dallas with a 530rwhp ZR1 who raced a single-turbo supra on pump gas....the supra made approx 540rwhp....they were even until 130 or so when they supra just walked away from him.
just my .02
Alex
And the C5 IRS is going to be a slight disadvantage, but the Supra's launching ability sucks. Almost all the fast drag MkIVs are running 9"s or 12 bolts, cause there just isnt anything out there for the stock Yota units.
If he's still pullin 12.6s, you should be able to walk him @ the track fairly well w/ some slicks, boltons and some skill imo. But in the mph/top end runs he will walk you
Don't know how important that is to you, but you will need a stroker with heads and cam to take him from a roll NA. That will set you back a lot of money. Bolt ons and a convertor is a a lot cheaper.
Dean
Change tires. ET Streets and skinnies.
Move rev-limiter to 6500.
Put gas in it.
Drive it like you stole it.
Put gas in it.
And if that won't do it add in a simple proven heads/cam/headers/gears/tuning package and Toyota boy will get owned. See www.cartek.net for some examples.
the fact that he's not going over 550rwhp indicates he doesn't have a fuel system (that's the limit on stock fuel system)
19psi means that was also on pump gas. race goes does miracles for turbo engines.
either way, this car should do at least 125mph quarter, which on the highway with a 6sp translates to some absolutely mad 80-150 dashes.
19psi on stock engine/fuel/cam/turbos can get you 124mph when tuned right, so a big single should do way better than that.
i think he's sandbagging, watch out, and spray the hell out of your car, you might be able to pull it off due to 500lbs less in a c5.
either way, i want a video
