Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
In the 10s!
Old Mar 1, 2008 | 10:12 AM
50_Dave's Avatar
Default In the 10s!
It is fun ford weekend here in orlando.
I got 3 runs at the track before i decided to call it a night.
These were on the spray.
The first one was 11.1 at 134 (I lost the slip).
The next two were the following:
Run2 Run3
60'- 1.636 1.609
330- 4.657 4.523
1/8- 7.026 6.866
mph- 106.10 107.19
1000- 9.075 8.880
1/4- 10.773 10.541
mph- 131.27 135.08
The second run my nitrous turned off on the 3-4 shift as i blew a fuse otherwise the mph would be close to the same, although the time might have been better. Im pretty excited as now I feel as if I can take the motor out and put the 402 and twins on now
Old Mar 1, 2008 | 10:49 AM
allngn_c5's Avatar
CONGRATULATIONS Dave !!!!
Very glad to hear all the LG Motorsports stuff and your driving added up to 10's at over 135 mph !!!
Old Mar 1, 2008 | 11:37 AM
scramblerman's Avatar
congrates. You got yourself a strong, fast Z06!
did you get some videos?
Old Mar 1, 2008 | 11:39 AM
50_Dave's Avatar
No, unfortunetly i did not.
Old Mar 1, 2008 | 01:53 PM
Red99TA's Avatar
Damn, not only are you in the 10's but you're deeeeep in the 10's! What's she run N/A?
Old Mar 1, 2008 | 05:20 PM
50_Dave's Avatar
My best n/a is 11.52 at 122. That was a 1.8 60 ft i think.
I have a bit more in it both n/a and on the bottle. We will see. We started putting the the 402 together today.
Old Mar 1, 2008 | 05:47 PM
Red99TA's Avatar
Nice. Do you plan on transferring the heads/cam over or going with something like AFR 225's and a bigger cam?
Old Mar 1, 2008 | 07:43 PM
robz*'s Avatar
Run2 Run3
60'- 1.636 1.609
330- 4.657 4.523
1/8- 7.026 6.866
mph- 106.10 107.19
1000- 9.075 8.880
1/4- 10.773 10.541
mph- 131.27 135.08
Nice going.
Can you elaborate on the nitrous setup? How much? How was it setup? Thanks
Old Mar 1, 2008 | 10:11 PM
50_Dave's Avatar
NOS kit with an NX fogger. The jets are a rich 175 shot. Probaly closer to a 150 shot as I like to keep things safe. It turns out, i ran on 2 melted plugs that night. I thought the car had a miss at idle, and i found 2 plugs, today, had the top part of the electrode missing. I suspect they may have been that way for a few weeks now as I tried to run the kit on a 150 shot and the car felt like it might have ran lean and fluttered some. I dont know how much of a difference it made last night, but who cares. Im really happy with the way the car ran.
Old Mar 1, 2008 | 11:20 PM
2002BLKWS6's Avatar
Congrats!
Old Mar 2, 2008 | 07:46 AM
choopak's Avatar
what kind of tires, what psi did you run, did you juice in first gear, also, do you have a stock rear end
Old Mar 2, 2008 | 09:28 AM
DocT's Avatar
Congratulations! That's a beast Z right there...Can't imagine what it's going to be like with a boosted 402
RT
Old Mar 2, 2008 | 10:06 AM
50_Dave's Avatar
I have a dte brace and stock rear end. The tires are mickey thompson drag radials (375/40/17).
I did use the juice in first gear. I pretty much launched on it, although i spun like crazy, it got it done. It seemed as if the higher i came out, the better the 60 ft/time. I was leaving at around 4-4500 rpm.
Old Mar 2, 2008 | 03:18 PM
Shoaf85's Avatar
Nice times man and hell I get nervous sparying a 75 shot on my H/C stock short block car I couldn't imagine a 150 shot!
Old Mar 2, 2008 | 04:08 PM
AlexLs1's Avatar
Congrats! Those are some great times.
Whats your race weight, if you know by any chance?
Old Mar 2, 2008 | 07:48 PM
algws6's Avatar
nice runs. what have you done to your fuel system?
Old Mar 3, 2008 | 12:25 AM
50_Dave's Avatar
My raceweight is like 3100 + my 240 pound heavy ***.
My fuel system is just an LPE pump. On the twin setup i am using a dual pump setup from lonnies with 60 pounders and supporting lines/feeds.
Old Mar 3, 2008 | 08:20 AM
allngn_c5's Avatar
Hey Dave, since when is 240 heavy bro ?? I go 6'4" 250 LOL. Just had to bust your ***** a bit.
Good luck on your Twin Turbo setup. When are you doing it ?? Also, do I remember correctly that it will be on a 402 ?? Can't wait to see those numbers.
Old Mar 3, 2008 | 08:54 AM
Sigforty's Avatar
I am with ya on the 240 comment. I am 300 so I would be heavy.
Old Mar 3, 2008 | 11:04 AM
allngn_c5's Avatar
Well Mark if you are pushing 300 lbs bro, theres always Sub Way !! Get your weight down to 250 and shave a tenth off your e.t. J/K bro.
