Corvettes Dyno #`s :
see my sig...might do some work this summer..maybe a 92MM Fast, maybe some cam work..I'd like to hit the 420-430rwhp range on a Mustang dyno at some point.
Here are my results and setup. 2001 M12 Z06 with 3.90 gears.
https://ls1tech.com/forums/showthrea...ght=383+futral
2007 LS2 M6 Z51 Corvette 446 RWHP & 404 RWHP
Mods:
Fast 90 Intake Manifold (Unported)
228/232 @ 112 LSA cam with double springs and hardened pushrods
Callaway Honker Cold Air Intake
Kooks 1 7/8" Headers, X pipe and high flow cats through stock mufflers
Underdrive Pulley
160 degree stat
Tune by Carolina Auto Masters
Mods:
Underdrive Pulley
160 degree stat
Here's mine:
04 C5 A4
A&A P1SC-1 , Kooks LT w/OR X-Pipe, Magnaflow Catback with DMH cut outs,
218/228 .600 lift 116 LSA cam, Patriot gold springs and titanium retainers, double roller timing chain, ported oil pump, 3000 stall , built tranny, 3.42 gears with hardend DS output shaft, DTE brace, on 305/35 Nitto drag radials.
All the work was done by G Force (thanks to everyone there)
Last time it was on the dyno it went 575HP and 505 TQ, but that was befor the gear change, bult trans , stall, and removing the cats
04 C5 A4
Mods:
Underdrive Pulley
160 degree stat
Mods:
Underdrive Pulley
160 degree stat
Then again a 224 w/ a low idle sounds great as well. So you don't have to go too big to acheive a great sound. But super mean sounds would have to be high 230's-low 240's w/ a 110-111 LSA. But those cams usually surge pretty bad w/o a really nice tune. MPG goes down significantly, too.
Here's a video with the lope sound:
http://s196.photobucket.com/albums/a...8-30-07003.flv
Also, I did a cam (i.e. mot heads) since it was going to cost a little over $3K for a set of ARF's installed on top of what I had already plan to spend.
I did all my mods at once and the gas mileage went from 18.0 to 15.5 gpm around town. I do not have any numbers for a long highway trip.
thanks for the info. I just looked at my post and what I ment to say is that I'm looking for something that doesn't sound crazy. I'd like a little lope but nothing that rocks the car bad or sounds like I'm trying to wake up the world. Nothing that hurts drivability or MPG is a must too but I'd like some nice gains from it.
Based on your comments it sounds like I should be looking in something in the low-mid 220's with a 112/114 LSA. Am I on the right track?
443/430 With two bad plug wires, bad O2's and a vaccum leak.
Mods.
413 c.i. iron block, forged internals, Stage 3 ported heads, 251/257-600/600-114LSA, Ported LS2 intake, LS2 ported TB, 42# inj., SLP longtubes, X-pipe and borla stinger cat-back.
Car is 99 coupe with 6-speed, OZ-700 clutch, Stock rear diff w/3.42s and ECS driveshaft.
Mods.
A&A race bracket. 7.5psi. Procharger twin intercooled P1sc,AFR 205's, harland sharp roller rockers, LG PRO longtubes, 3" offroad X pipe, B&B bullets, FAST 90 90, 233 237 .649 .598 on a 112 camshaft, siemens 60 lb injectors, racetronix hotwire/pump kit, diablosport PCM tuning...and a bunch of random ****.
6 speed. 2005 block. 3.42's
