2001 zO6 vs. 2002+ zO6
and also from the guys with the '01's that will say "blah blah blah."
Here's my blah....
I own an '01.... and I also work in a Corvette only dealership that lets me drive everything from a $250,000 irreplacable '67 to a beater C4....
(a link to a $250,000 test drive (1 of 4 in existence that sold for $300k at Barret Jackson....during the last 3 mintues the car is driven as close to full considering it's consigned and irreplacable-- at 6 minutes,15 seconds the video becomes magic!!!) http://videos.streetfire.net/video/A...-of_135072.htm )
The 20hp difference will almost not be felt in most cars.... I've felt freak '01's like mine and dog '04 Commeratives...
Buy your '01 or '02+ and love it because it's YOURS..... with a bigger cam and headers who cares that the '02 has 30 thousands more lift on the cam when you've added one HUNDRED thousands lift and 10 POINTS in duration with an aftermarket camshaft... and who cares if you have 4 cats (01) instead of 2 (02+) when you've got long tube headers and you've deleted the cats anyway...
My $.02
To say it another way...
I drive an '01 and love it.... I'm hard on my cars... I'm easy on cars that aren't mine.... but I drive my stuff like it's stolen (within reason of safety and margin)
Who cares about Zo6's? get a base C5 and you'd be happy...
Have you driven ANY C5?
Good luck man, what I had to say was mainly in my first post...
Maybe others will chime in with their opinions..
I will say though, ANY Corvette bought in good condition is a great automobile to have....
I support America in every way, choosing a Corvette is a great choice.
I'm just kidding. The above statement is completely true about modding. The minimal power difference is easily surpassed with a cam. Hell I'm sure an '01 with a CAI, LT's, and dyno tune will pull a bone stock '02. Point being that they're pretty close in my opinion. I say get the best condition car you can afford whether it's an '01 or '02+. They both handle like a dream, look the same (minus the "405HP" on the badge), and you'll be happy in either one.
I say get an 02 + but that's just me. I would not buy a base C5 over a Z. I mean maybe if your driving around in a beater and going to a Vette yeah it would be a nice jump, but I wouldnt buy a Vette if it wasnt a Z or boosted
http://www.jakelatham.com/c5/misc/differences.shtml
2001
return to 28# injectors for all models.
Second Generation Active Handling
Nassau Blue discontinued
Alternator 'clutch' pulley added on A4 cars
New soundproofing + foam in all cars
Smaller keyfob
electrochromic dimming rearview and driver's mirrors
lighter AGM battery
Thickness + Material in vert change
Chrome exhaust tips for coupe + vert
85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
All Corvettes now have the LS6 intake manifold
All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
Hardtop/FRC discontinued
Pup cats added to all models
Stronger synchros in all transmissions
Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
metal valvestem caps (late year)
Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in dia from 55 to 63 mm.
Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
Introduction of the Z06, which has as differences:
hardtop body style
rear brake ducting
screened inlets on front fascia, without foglights
F1 supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
new LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff
Titanium exhaust system
lightweight windshield
New, stronger clutch with redesigned master + slave cylinder
Stronger rear differential (shotpeened ring gear)
Red brake calipers (otherwise identical)
Trans overtemp warning light on DIC
6500 redline gauges with special checkering + Z06 font
redesigned PCV system to help combat oil burning
Red LS6 Fuel Rail Covers (FRC's)
FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
2002
Z06 Changes:
Z06 LS6 cam changed to: 0.551/0.547, 204/218 on 117.5
Less restrictive intake airbox lid
Descreened MAF
Removal of pup-cats (total with changes = 405hp)
Z06 shocks revised with less rebound for better launching
Z06 brake pads revised for better stopping (generate more dust)
Lighter, sodium filled valves w/ stronger valvesprings
higher tension rings installed to prevent oil burning problems
slight piston redesign *
clutch strength upgraded.
HUD available on Z06 (not avail '01 model year)
Wheel supplier changed to Speedline, moved from forged to cast. Weight nearly identical
Electron Blue color offered
Steel endlinks changed to aluminum
I have a friend with a 03 Z06 with Vararam Intake and I have a 01 Z06 with Halltech Intake.... Side by side all they until around 130 or so and then thats when his extra power lets him edge me out.... Barely.
I have an 01 Z06 with 19k miles on it and love it!!!! Like JOSHUA said.... There were only a few changes that made the 20hp difference. Change the cam and put a fulle exhaust on it and a 01 will put down what a 02+ will....
Good Luck!!!
) and it dynoed 320.6 whp and 318.3 lbtq....keep in mind most cars lose about %12-15 thru the drivetrain...thats about 60hp...im right where i should be...the way i see it u wont be dissapointed, wether its an 01 or 02
