Fastest N/A, Cam Only, all LS engines
#201
up untill the other day he edited it about the cam, was claiming it was a LS6 cam.
No comment about about SSP saying the valves are not stock?
There is alot of new stuff that wasn't out 10 years ago. This isn't a nostalgic cam only chart Any pcm is fine, Maybe even a carb and super vic, or 2 carbs on a hi ram if you want to port it for the small head ports. Comes down to the drop in springs a stock lifter/rockers valvetrain will limit your rpm, outside a OEM style intake... or how much you want to wing it it not happy. lol. Theres some good parts out there to add some power on a stock engine. Theres 10-12whp with a moroso vac pump setup. Cant do any oil pan or oil mods, i found the improved scraper is about 10whp.
#202
