First track runs a little disappointed
I Finally got my car to the track. I know that my gears are killing me 2.73's. Here is my best time
Reaction .84
60 2.37
1/8 9.22
1/8 Mph 80.88
1/4 13.88
1/4 Mph 104.85
I was racing in Gulfport Ms not the best track ever and I just spun and wheel hopped through my 60. Mod's are in sig. I also have street tires.
What do you guys think I can do to get faster I am getting a LS6 Intake next week. I do not have the money for more mods right now and i go on deployment in a few months and then i will save up for a stall and gears thanks for your help.
Reaction .84
60 2.37
1/8 9.22
1/8 Mph 80.88
1/4 13.88
1/4 Mph 104.85
Drag radials, some hoosier cheater slicks, thats what I put on mine. Make sure your the tire isnt too tall, you can get away with running something as small as a 235 or a 245 because of the compound of the cheater slicks (and there dot approved too). Gears would also, obviously help.
Your rear will be fine with an auto. Tires first. Your car really came alive on the second half. A 9.22 1/8th mile is close to being a 14.30-14.40 1/4 mile time, so you made up a TON of ground of the second half. Get it out of the hole good and it will look something like this:
60 foot....1.90
1/8th......8.60
1/4.........13.20ish
mph........106
I don't think your car has a high 12 in it just yet. The stall will get you there though.
TIRES FIRST!!!!!
60 foot....1.90
1/8th......8.60
mph........106
TIRES FIRST!!!!!
Either the track prep is crummy or you've bald tires. Nothing wonderful here, but I usually get in the 1.9-2.0 range with 245mm Kumhos. Granted they had good tread, but drag radials may bog you down on those stock gears. I ran 13.4s at 104 when mine had nothing but a lid. You're trapping good enough for those times; even with that horrid 60.
I swapped to 3.73s and can't hook for **** on the street. If prep is right, the track might be another story. Sometimes I had to baby it at the strip and sometimes just knock a dent in the floor pan and dead hook.
Edit: I didn't read your mod list.. Then again, I've run anything from 12.9s to 13.8s with my headers. On balder tires in hot weather, it was in the mid to high 13s. I was pissed because I ran better before bolting them on. Get a good hook and see how she does. If it doesn't flirt with 12s, it ain't running right.
