CAM ONLY NEW BEST 10.617 at 124.66MPH!!!!
#45
Caught some good air today and good track prep
DA -872 at the time of the run
662 Elevation
41* Temp
30.39 Baro
22* Dew
Now for the goods
First pass of the day the car lifted the tires higher than it has ever before, and i knew it was going to be good day for a new PB...
Next pass stalled it up as high as it would go and pulled off a
1.3670....60ft
4.2681....330ft
6.7278....1/8 99.79MPH
8.8509....1000ft
10.6539....1/4 125.06MPH
next pass was my best mph
125.33MPH
Final pass i made staged shallow and gave her hell
1.3561....60ft
4.2399....330ft
6.6919....1/8 100.18MPH
8.8138....1000ft
10.6170....1/4 124.66MPH
Things that have changed since my 10.81 at 122mph in -400 da is the air, FAST 92, 12 bolt with 4.10...raceweight is still pretty close to what it was(lost some here but gained some there)...
since i took the mods out of the sig cause it was getting too crowded here they are
Engine
230/230 cam
1 3/4 qtp headers (non hvmc)
ORY to Cutout & stock catback
my custom ram air
Ported Fast 92/92
85mm truck maf
25% UD pulley
85mm FTP lid
Suspension & Others
SS4000
TCI Flexplate
rear lca's
weld in SFC
midwest chassis tunnel mount tq arm
spohn rear drag bar
panhard
aluminum spooled 12 bolt, 4.10s
275/60/15 (28") M/T drag radials
qa1r single adj front shocks
stock rear shocks and springs
SPEED INC. TUNED
662 Elevation
41* Temp
30.39 Baro
22* Dew
Now for the goods
1.3670....60ft
4.2681....330ft
8.8509....1000ft
125.33MPH
1.3561....60ft
4.2399....330ft
8.8138....1000ft
Engine
230/230 cam
my custom ram air
Ported Fast 92/92
85mm truck maf
25% UD pulley
85mm FTP lid
Suspension & Others
SS4000
TCI Flexplate
rear lca's
weld in SFC
spohn rear drag bar
panhard
SPEED INC. TUNED
Keep chipping away at that number!
N2
#47
Good job Chris, not bad for a little reverse split cam (at some lifts at least )
Awsome combo, well done, now you know why I called it "THE BULL". its bigger bros 236/236 does well in a 408
I wish I had been there to see it in person, any videos??
#49
probably like 75 or so i only do a quick burn out...it is all it needs maybe 4 secs...usually 1 sec longer after i see smoke...plus you can ad in the 3k or so street miles....this was before the spool so i will see how long these last...probably not as long
#51
But when you think that heads up, with good reaction time, it will take a shitload more power to "reel" you in on the back half.
That is how I win the majority of my races, for the back half, I let the drugs take over (limited injection of hilarious substances)
#52
im about to ask a stupid question in the eyes of most of you.
what makes you able to lift your car like that?
Besides the obvious. Its just that Ive seen cars that are just as fast. or close to it, not be able to...
#55
nope no NHRA track...if it were an NHRA track i would just run it out to the 1/8 and if i thought it was a good run i would keep my foot in it and get my warning for going to fast...then i would have one more full out run before i get the boot...so even at a nhra track you can get two 1/4 mile runs in
