Mild Bolt-On Car...2.73s killing me?
Old 04-29-2010, 06:13 PM
Badger351's Avatar
Default Mild Bolt-On Car...2.73s killing me?
'01 Trans Am A4
What I've got done: Lid, K&N, ported throttle body, ported and de-screened MAF, Borla Catback
She put down 328hp and 352ftlbs the day before on the dyno.
I was hoping for a 12.90 but the car didn't seem like it wanted to move until it was way past the 60' mark. Obviously 2.73s will do such a thing.
Question is...with a 3.42 will I have a 12.90 car? Not sure if it'd be enough to take me down an entire half a second.
2.11 60'
5.80 330'
8.79 1/8 - 83.17 1/8 MPH
11.30 1000'
13.42 1/4 - 105.59 1/4 MPH
Old 04-29-2010, 07:38 PM
NHRAFORMULA00's Avatar
Put a ss3600 in it and you will have a 12.50 car,with the 2.73 gears.
Old 04-29-2010, 07:41 PM
Sy99T/A's Avatar
Yes, definately stall the car and don't look back. Night and day difference in the car
Old 04-29-2010, 07:46 PM
JOSH13's Avatar
I haven't dynoed my car yet but I also have the stock 2.73s . I think the 2.73s are hurting my times also . I have a stock set of 3.42s I am about to try out .... I got them cheap so I figured why not go that route .... I ran a best of 8.46 in the 1/8th with pretty much full bolt ons minus gears on street tires. I'm not sure just how good that is ....
Old 04-29-2010, 07:47 PM
JOSH13's Avatar
I also trap at about 87
Old 04-29-2010, 08:28 PM
FASTEDDIE Z's Avatar
Originally Posted by Badger351
'01 Trans Am A4
2.11 60'
5.80 330'
11.30 1000'
I dont know if it would get you there . I had 273s ,magnaflow c/b , SLP lid and went :
2.04 60 ft
8.8 @82.5mph 1/8
13.49 @105mph in the 1/4 1/4.
Then did 373s D/radials and went :
1.9 60 ft
8.4 @84mph 1/8
13.16 @106.5mph in the 1/4
I might of squeezed a 13.0 ,,if I didnt get kicked out .
With good air and traction it is possible for you to click off a 12.9X . To make sure I make it next time ,I did a Yank SS 4000 stall ,tune and suspension .The converter was a much bigger difference than the gears .Gears will help ,but a converter will probably help more . They go nicely together
Old 04-29-2010, 10:01 PM
Tommyv8's Avatar
Last October I went from 2.73s to 3.42s and picked up maybe 2 tenths with all else being equal. Although my best time with the stock converter and 2.73s was 12.72 @ 109, just like my best ET with my current setup (stock converter, 3.42s last month). The run with the 2.73s was a few years ago and my car had a lot fewer miles on it than it does now so maybe that has something to do with it. The DA is always a factor too, although both runs in question were done in pretty good air.
Old 05-02-2010, 02:00 PM
Badger351's Avatar
So I guess I'm not too far off then from where I should be at. Thanks for the advice guys. I won't be doing a converter for a little while...it'll come after exhaust and gear.
I'll be back at the track with 3.42s, full exhaust, and a new tune in a month or two. 12.79 possible?
Old 05-02-2010, 02:05 PM
SexyTransAm's Avatar
hell with the 2.73s put a ss4000 in and dont look back
Old 05-02-2010, 02:10 PM
Trunion King
bene's Avatar
You're leaving alot on the table if you're putting the converter as one of the last mods.
Do LTs, 3.42 and a Yank stall, go atleast 3500 and you're def in the LOW 12s. Of course this ET is with a set of good sticky tires.
Trunion King
bene's Avatar
Old 05-02-2010, 02:14 PM
but i did pick up .4 goin from 2.73 to 3.42s
Old 05-02-2010, 05:01 PM
Xtreme864's Avatar
full exhaust+slicks should have you at a 12.9 even with 2.73's.
Old 05-02-2010, 07:56 PM
dannyz's Avatar
Four tenth's from 2.73's to 3.42's alone???
Come on.
Old 05-02-2010, 07:57 PM
dannyz's Avatar
I could see a couple tenth's, but four?
Old 05-02-2010, 08:51 PM
Badger351's Avatar
The converter is the most expensive thing to do, hence why I have to wait. I can only do as much as my college wallet lets me at the moment.
BUT, a converter doesn't immediately require a tune to gain it's full advantage like the rest of the exhaust and a gear. Hmm...
.4 off a 3.42 would be nice and I could see it given the quality of air before and after. You could've just had gone on a really crappy night, switched gears, and gone again on a much better night.
Old 05-02-2010, 09:52 PM
Come on.
its no lie!
Old 05-02-2010, 10:16 PM
Xtreme864's Avatar
I've seen four tenths gained from a gear swap before but i'd go with 3.73's for an auto over 3.42's. Not as streetable but still gives you a good power range
Old 05-02-2010, 10:37 PM
yea i would have done 3.73 but i got one hell of a deal on a rear out of a m6 car.
Old 05-03-2010, 10:05 AM
Goat2NV's Avatar
The gears hurt, but they aren't hurting you that much. With full exhaust and drag radial, mine goes consistant 12.8s and its been a best of 12.4. Get you a decent stall and cooler. Your 60fts will drop and so will your ET. But you've got more in it as it stands, I 1.9s with my stock stall and street tires.
