Cam only TBSS record 11.972 @109.82mph
Even though I was just at Byron on Monday, cracked off 12.0x after 12.0x pass, and even set the fastest cam only tbss record, i wanted more!! I went up to GLD tonight immediately after work in search of an 11 second pass. DA was at 433' at the time of the pass, and the truck weighed 3980lbs without me in it.
![](http://i52.tinypic.com/31314b4.jpg)
I am one of only 4 trucks to run 11s N/A on the stock bottom end, the other three are heads/cam. My truck also 60's faster than all but three TBSS on the planet. Those three trucks all make over 1200whp and run 9.0x
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
That is rolling! I built one a few years ago that went 11.84 @114 stock bottom. Can't remember the 60, around 1.8 though I think. Had cam, lt's, TFS 225's, pulley, and Yank 3600. Truck was full weight on 20's with nitto DR's in the back. Was a big deal 3 years ago. Made 440 unlocked. Guy that owns it parted it out and moved on. Love the TBSS though. Great all around ride.
It was on the stock 4.10 gears, M&H 275 55 16s (28" tire), not quite skinnies but I do have a 225 up front on a 16" wheel to save some weight. The cam is a custom grind, specs are hush hush for now.
I remember your truck actually. There are still only three heads/cam trucks in the 11s that anyone knows about.
Nope, on the stock belt driven unit still.
![](http://i174.photobucket.com/albums/w86/howark/th_Jared1.jpg)
![](http://i174.photobucket.com/albums/w86/howark/th_Jared2.jpg)
![](http://i174.photobucket.com/albums/w86/howark/th_Jared3.jpg)
![](http://i174.photobucket.com/albums/w86/howark/th_Jared4.jpg)
![](http://i174.photobucket.com/albums/w86/howark/th_Jared-5.jpg)
http://youtu.be/N5-8-yURfRM
http://youtu.be/KCYZaTPn-O8
Me vs. a bolt ons & tune C6ZO6
Custom grind spec'd by my tuner. Fast Motorsports out of Algonquin.
