104.41 trap in the 1/8th = ??? in the quarter?
Got a chance to finally get out and race in some good cold air. Anyways, I trapped 93-94 on motor and 103-104 on the juice, my highest being 104.41, what do you all think that would be in teh 1/4? my calculations put it at right around ~131. does that sound about right?
I always use 1.55 for the ET and it always works out really close for me, so im covered there.
I know, its a damn shame that the local 1/4 mile track wasn't open last night.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
This is what I came up with as a theoretical pass based on that 1/8th mile MPH:
60 Foot 1.41
330 Foot 4.14
660 Foot 6.51
660 MPH 104.41
1000 Foot 8.56
1/4 Mile ET 10.32
1/4 Mile MPH 128.43
60 Foot 1.41
330 Foot 4.14
660 Foot 6.51
660 MPH 104.41
1000 Foot 8.56
1/4 Mile ET 10.32
1/4 Mile MPH 128.43
Your a 6 speed Chris...that MPH in the 1/8 is gettin it.
I have several timeslips here with 104-105 eighth mile traps and from 131 to 135 in the quarter. Anywhere from a 10.3-10.5
closest example I have is:
1.553
6.788
104.54
10.482
133.51
Keep up the good work and you should be bottom 10s. Just remember to use 100 or 104 unleaded.
1.553
6.788
104.54
10.482
133.51
When I was cam only with a 100 shot I went 10.49 @ 129.06, the 1/8th mile mph was 103.11, so you should be around 130, maybe a little higher since ur a 6-speed, here's my old slip:
dunno if this helps, but this is what i ran last weekend.
Stock bottom end, heads/cam, bolt on , th350,150 wet shot, leaving at 3200 off the T Brake, 3.73's , 8.8 rear, w/ 325/50/15 MT Drag radials. race weight around 3500#
60' 1.374
330' 4.165
1/8th 6.507
MPH 104.87
1000' 8.536
1/4 10.259
MPH 130.51
that was the first nitrous pass i made on the th350, and it has a 4200-4400 stall, so it has more left in it. just gotta wire the nitrous up, so i can do a full T Brake launch
60' 1.374
330' 4.165
1/8th 6.507
MPH 104.87
1000' 8.536
1/4 10.259
MPH 130.51
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
1.553
6.788
104.54
10.482
133.51
1.553
6.788
104.54
10.482
133.51
Originally Posted by Bad Habit Bird
What did you run on motor, how much were you spraying?
this was with my old 383 setup that made about 420 on motor. I usually ran about 11.4-11.5 all motor at 120-121.
The 10.4 timeslip above was probably with a 75/75 dual stage for a 150 total. Although it was so long ago I dont really remember. Ill have to look at the back of the timeslip to see if there are any notes on it.
With the same setup and dual stage 100/100 (200 total) it was 10.0 at 138 and 6.4 at 107.6 in the 1/8.
Damn Chris 104.x at 1/8 mile is enough to trap over 130 mph at 1/4 mile buddy & i think LS1tech members already proved that
Btw do ya have any footage from that night ?!
peace
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
peace
Those estimates are close to what my car ran last year with my old setup. I ran quite a few passes and on the 175HP jets the slips looked like this:
1.52 60'
6.52@105mph
10.23@132mph 3.42 gears with 325/50/15 ET Street Radials
200HPNX
1.53 60'
6.50@106mph
10.17@133mph
1.52 60'
6.52@105mph
200HPNX
1.53 60'
6.50@106mph
10.17@133mph
Thanks for all the replies! looks like I will have to wait till next december to get anymore cold air down here to find out. was at the local 1/4 mile yesterday and it was about 30-40 degrees warmer than the night i trapped 104-105 could only trap 100-101 yesterday in the 1/8th and the 1/4 mile traps were 127-128
