camaro front bumper support...
Anyone have a write up, I've been searching for a while but cant find a write up. I'm looking to drop some weight off this heavy car, but also dont want to end up with any sag(think its more of a ta issue but not 100 percent sure)
It's not that hard and I didn't use any kind of instructions. I found taking off the black plastic piece more trouble than the bumper support. If you can do any kind of mechanical work then it should be a breeze.
comes off easy. undo the bolts on the frame-horns and remove the plastic pop-in clips on the botton. break the **** outta the styrofoam and remove styrofoam in pieces and then remove the support brace. i have had no probs with my bumper cover sagging or anything at high speeds
i took mine off and used a pice of retangel tubing and bolted it across then modifide the hood latch and suports and welded them back to it i will try to git sum pics up of it it weighs around 4-5lbs
