Drag Racing Tech
shock, coilover, spring QUESTION
Old Feb 18, 2009 | 11:12 PM
nemss1's Avatar
Question shock, coilover, spring QUESTION
sorta confused on the coilover setups. if i switched to coilovers, would the coilover eliminate the spring in the stock location in the rear?
Old Feb 18, 2009 | 11:18 PM
Heyfred's Avatar
Yes
https://ls1tech.com/forums/drag-raci...per-build.html
Old Feb 18, 2009 | 11:27 PM
nemss1's Avatar
thats what i figured. plan on removing my konis and springs for a coilover setup. my car has 1" lowering springs. could i still keep the car lowered an inch with coilovers?
Old Feb 18, 2009 | 11:34 PM
Heyfred's Avatar
yes
Do you have some coilovers already picked out?
Old Feb 19, 2009 | 06:48 AM
nemss1's Avatar
no, havent decided on a particular. out of KYB, AFCO, QA1 which ones do u recommend?
which ones are u using?
Old Feb 19, 2009 | 06:51 AM
z28rob18's Avatar
i dont have the coil overs but out of those choices id definatly go with afco's
MADMAN's Avatar
LS1Tech Sponsor
Out of the ones you listed AFCO is the only choice. I keep them in stock give me a call.
__________________
www.madmanandcoracing.com
225-343-9029
Old Feb 19, 2009 | 07:00 AM
nemss1's Avatar
ya so far frm researching, i liked the AFCOs the best and madman, ill definitely let u know when i scrounge up the money for a set
Old Feb 19, 2009 | 07:09 AM
z28rob18's Avatar
dont want to hijack but whats the benefits to coil overs instead of the stock set up?
Old Feb 19, 2009 | 10:54 AM
Steve Burger's Avatar
LS1TECH Sponsor
+1 for AFCO
Old Feb 19, 2009 | 08:54 PM
nemss1's Avatar
heyfred, noticed u didnt have a rear swaybar. heard u can remove the rear swaybar if right, spring/shock is stiff enough to not let the body sag down on the right side when the chassis tries to twist to the right
this true?
think im going to go with QA1 double adjustables since they are good streetability for the streets as well
Old Feb 19, 2009 | 09:48 PM
Heyfred's Avatar
I just removed it becuase I am getting ready to take the 10 bolt out.
You can run without the rear bar, but it will take more setup time. I am going to run a rear bar on my 9" setup when I get it. After talking with several people on the board, the rear bar helps to makes the car launch straight.
Old Feb 19, 2009 | 10:18 PM
nemss1's Avatar
thats what i figured. also thinking about going with strange calipers/rotors
if i needed brake pads ever for the strange setup, would i have to order them frm strange or can i get them at a parts store?
Old Feb 19, 2009 | 10:39 PM
Heyfred's Avatar
Can't answer that, but one reason I stayed with stock brakes is, I can fix or replace quickly if needed.
My car is not going to be a strip car only. I want to be able to drive at anytime.
Old Feb 19, 2009 | 11:21 PM
nemss1's Avatar
any other companies besides PA racing that makes a lightweight spindle???
Old Feb 19, 2009 | 11:42 PM
Heyfred's Avatar
racecraft
Old Feb 19, 2009 | 11:47 PM
nemss1's Avatar
ill check into that. trying to shave as much weight as possible before spring
ive noticed alot of the rear drag brake setups are 4 piston rear calipers instead of 2 piston rears like stock
are most of the rear drag brake setups 2 piston setups???
Old Feb 20, 2009 | 01:17 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
1) most of the rear drag setups are 4 piston, due to the average weight of a car. the 2 piston brakes are for the front of cars that are under 2600 pounds.
2) why run QA1s? Strange is a better shock and believe it or not is less cost. by far the best bang for the buck. AFCO shocks are one of the best on the market for drag shocks, but also in the higher price range. the average user with a street/strip car performs fine with Strange shocks.
3) the AFCO shock setup in the above pictures is what i set him up with. the ride height is adjustable, you lose the stock heavy spring, and the shocks are externally adjustable for valving control.
4) i offer all the Strange shocks and brake components you need. i also have a Strange front brake kit that uses the factory spindles and hubs, and is far less cost than the normal kit.
pm me for details
Old Feb 20, 2009 | 08:16 PM
nemss1's Avatar
ya im going strange coilovers instead. heard some people having problems with the QA1s. i would go with AFCO, but its not in my budget
also, what are you guys opinion on drag brakes on a car that rarely sees the streets but as a fair weather/occasion type thing?
heard rotors on a drag brake kit can warp frm getting hot frm stop and go traffic
Old Feb 21, 2009 | 12:57 AM
ssvert99's Avatar
^^^ this is partially true, but it all depends on how you drive the car. the rotors on the race kits are relatively thin and would be subject to warpage if abused. i run the Strange race brakes all the way around on my own car and have other customers with them as well, its just a user thing... you have to understand that the brakes were not designed for stop and go traffic. maintenance may be required and there is never any type of warranty with this application. not that it can't be done, but you have to understand the big picture.
