Drag Racing Tech
Cam only, winter upgrades. Bitch in on a diet
Old 05-29-2012, 10:09 PM
  #741
studderin's Avatar
ya rpm stocks faceplated parts, and are a lot faster them liberty that dose your set and you wait the 4-6 weeks or whatever it is. Call them for sure
Old 05-29-2012, 11:41 PM
  #742
98blueSScamaro's Avatar
did you just do stock faceplated parts or did you do full upgrade???? and if you dont mind what did you pay.
And Studd love the face your rocking drag Rad's it can be done just takes time , effort and money$$$$
Old 05-30-2012, 06:33 AM
  #743
HioSSilver's Avatar
Good to know. I have a spare I would like to get done.
Old 05-30-2012, 07:02 AM
  #744
nocooler's Avatar
Call RPM and talk to Jeremy or TJ. They are awesome to deal with.
I'm kinda wishing I would have gotten mine face plated - but my junk is heavy and slow.
Old 06-02-2012, 06:06 PM
  #745
studderin's Avatar
Originally Posted by RENE'S RAGE
What oil baffle is that. I like. Does it work.
improved racing, look a few pages back for pics in info on it.
It alot better then stock, I haven't looked down at oil pressure yet at the track to see, I'll try to get a gopro to pick it up.
Originally Posted by Nitroused383
Congrats, so what did it run?
at the moms event, low 11's but super consistent, 11.22,11.21 11.18 11.15 11.20, it was spinning 1.7 60's. It was in the low 90's and track temps were 150 I was told. But I did this week go a bunch off 11.0s and a 10.98 and a 10.98 at 127.5ish. Thats the 1st time the cars gone 10.9 in street mod, so Im happy. Still spinning best 60" was a 1.6X turning the 2step down to 5500 form 5800. And of last year I was getting low 1.5s and hi 1.4s with it 6200 and 6500, moving the shock setting around (in the normal range), and tire pressure but I know what the car likes. But could keep the DR form spinning on the hit. DR are at the wear bars so think it might be them.
Mike at Newera went a 11.4 121 is the ZL1 camaro with a 1st protype intake, he tuned it, and put DR on it (smaller then stock) that night. Last time it went a 12.0 120 bone stock
Just remembered I lowered the front mount of the TA one hole, over winter so that might be it too. I haven't missed a gear yet, and the cars super consistent. I'm only WOT shifting the 3-4 most of the time. I guess I should do the 1-2 next, the cars moving at a lower speed so thats the best place to gain.
Got a new intake came in the other day, along with another one. No more wipers
Old 06-02-2012, 07:08 PM
  #746
studderin's Avatar
sawall time
lots of taper, and you can see right into the chamber
Old 06-02-2012, 07:27 PM
  #747
studderin's Avatar
Any tips for getting the wipers off!!!
haven't touched mine. 2001 no winters with about 80K, but like everything else on my car its not going to go easy. The Few times Ive helped on other cars It was a HUGE pain in the ***. I dont think Ive ever gotten both wipers off like GM says too, easily with tools. Its beating the **** out of them, and chewing them all up.
Old 06-02-2012, 07:38 PM
  #748
95killerz's Avatar
I usually try to soak them with wd40 and flip them up and wiggle back and forth using the arms as leverage
Old 06-02-2012, 08:19 PM
  #749
EDS01SS's Avatar
go to advanced auto and get the wiper arm removal tool....its cheap and well worth it
Old 06-02-2012, 08:29 PM
  #750
nocooler's Avatar
LSXRT? nice
Figured you'd go victor jr. and a 4 bbl tb
Old 06-02-2012, 09:46 PM
  #751
studderin's Avatar
I have a super vic, but its big for stock heads. This is sized alot better for sure.
The holley cast ram thing looks good too (port size) But been waiting for one for 6 months now. and "2 weeks" for like 3 months now...all winter, its june already.
I bought this from Newera, Mike had it the next day after I said to get me one
And the LSXRT I can run in the MIR WRF all motor class-
Induction: Engine must be EFI. All OEM intakes are permitted. The only aftermarket intakes permitted are: BBK intakes, Typhoon intakes, and Fast 78mm, 90mm, 92mm, and 102mm intakes
Ya, I looked it up and they have a tool, and some used a battery terimal puller sorts fits too, they got to work. Mine are stuck, I'll try to get a tool tomarrow
Old 06-03-2012, 07:48 AM
  #752
BADD SS's Avatar
The battery tool works, they also make a specific wiper arm puller. With either, use some aero kroil or Pb blaster, soak them, let them sit, then attach the puller and tap with a hammer lightly...
Old 06-03-2012, 06:55 PM
  #753
studderin's Avatar
got a wiper tool, looks like a POS and gona snap easy. Looking for my old valvespring claw style puller, I think might fit
Old 06-04-2012, 01:23 AM
  #754
98 grmrpr's Avatar
Try a home remedy for loostening rusty parts, 50 to 50% mix accetone to trans fluid to it will beat anything else you comapare it to!
Old 06-04-2012, 11:25 AM
  #755
Default 102 truck intake
Here are some pic's for you. a good amount of cutting and a little fab work but thats the easy part. keep us posted on this and what hood fits it. the car we did is still hood less
Attached Thumbnails Cam only, winter upgrades. Bitch in on a diet-078.jpg   Cam only, winter upgrades. Bitch in on a diet-077.jpg   Cam only, winter upgrades. Bitch in on a diet-076.jpg   Cam only, winter upgrades. Bitch in on a diet-075.jpg
Old 06-04-2012, 11:28 AM
  #756
SIC LSX's Avatar
u can also make some k-member spacers so u dont have to cut as much
Old 06-04-2012, 11:37 AM
  #757
we really didnt like the idea of spacing the K due to susp setup and all. so we just cut it. plus it had to be cut any way so why beat around and change more then one thing. just keep it simple.
Old 06-04-2012, 11:55 AM
  #758
nocooler's Avatar
damn that intake is huge. It'd probably be a tight fit even on my TBSS!
No way to keep the drivers side wiper I guess.
Old 06-04-2012, 04:49 PM
  #759
SIC LSX's Avatar
The only car i helped put them on gets 1.25 60ft on 275/60 DR all day long. he only used half inch for carb to clear hood. We just adjusted the coilovers to get back at same ride height. told few others about this running roots blower didnt have any problems and i think stangkilr made some too on his turbo build
Old 06-04-2012, 06:12 PM
  #760
studderin's Avatar
got side tracked to finshing cutting last night, but started. Its gona be close but I think it will fit. Got the HF body saw, and cuts ok, its not variable, just 100% on, But has a small base so you can cut right along the glass easy. Using that and a jigsaw, no sawzall, but I'm really good with both.
Got the wimpers off, they were reall stuck. The tool was gona break for sure I thought. The final POP was worse then some ball joints loud.not big bang but little gun shot pop. I really thought the windshield broke, or the wiper post cracked off the shaft or something. The tool only fit under the diver side, the pass (middle) was to tight under. So had to tap the lower foot under the arm from the side, then pull it off normal with the tool. Soaked them in PB blaster for maybe 24hrs, tapped on them a few times, kept the puller tight and tapped on that, ended up using big channel locks on the ****, and hitting it down hard.
The hood should be fine. I think I left a 1/4 metal past the glass, But oince I cut the bottem out and get it to go back I can see. I need to be able to un do the trans Xmember and let it tip back for track swaps so I want to have to room, without pulling the intake to tip it back. The windshield is a little off the metal, sitting on like 1/8-1/16 of the black sealer so you can cut the metal flush, even Back cut it a little behind the end of the glass I looks like. I took some good pic with my real camera, if it fitting (all the parts) to the car, and the specs of the intake, runner CSA in/out, lenght, taper, ect. And mocked it up on stock heads. I'll post up later
Pics I sent to mike (new era) last night. haha
Quick Reply: Cam only, winter upgrades. Bitch in on a diet
