Super Victor LS1 intake/408ci Direct Port Nitrous
NOW WITH INSTALL PICS
UPDATE: Motor is in and the Super Victor LS1 fit's under the cowl with a low profile Edlebrock elbow. The lower layer of metal on the cowl had to be trimmed away, the hood trimmed and the silenoids and hard lines manipulated. Everything clears and motor mounts welded solid to minimize movement. 2nd round of new pics added. Thanks for looking
![](http://i27.photobucket.com/albums/c198/Texasvortex/n202306355_31632544_1581687.jpg)
![](http://i27.photobucket.com/albums/c198/Texasvortex/n202306355_31632545_657851.jpg)
![](http://i27.photobucket.com/albums/c198/Texasvortex/n202306355_31632546_3414536.jpg)
![](http://i27.photobucket.com/albums/c198/Texasvortex/5572_532720967774_202306355_3163255.jpg)
Has anyone done this yet? I am but found I need to do alot of cutting not only for the elbow but for the nitrous plumbing and silenoids. It appears we may even have to cut the cowl far enough left and right that I may loose my passenger windshield wiper. In addition the underside of the hood is going to require cutting too. Even the rear nitrous plumbing lines hit the cowl. Nitrous silenoids and lines are being adjusted downward. When the intake was plumbed we didn't have the car to trial fit.
Would like to know if anyone has been through this yet in their 4th gen?
Also where are you guys tapping in for the brake boost and air conditioning vacumn lines?
The silenoids in the pic have been turned on their sides but still way too tall to clear the cowl.
![](http://i27.photobucket.com/albums/c198/Texasvortex/IMG_2703.jpg)
![](http://i27.photobucket.com/albums/c198/Texasvortex/IMG_2701.jpg)
![](http://i27.photobucket.com/albums/c198/Texasvortex/IMG_2717.jpg)
![](http://i27.photobucket.com/albums/c198/Texasvortex/IMG_2714.jpg)
I did that and ofcourse it helped, but still way tall. I will get some pics up soon. I'm thinking I will just have to cut alot more than originally anticipated.
Race your car!
You're gonna find out that the elbow that you have on there isn't gonna work. That thing is a POS and will choke the motor like you don't even know, nevermind it distributes like ****.
Get that thing off and right in the trash, trust me it will save you alot of headaches. Carb style TB is the only way to go with what you are probably trying to do.
Im planning to run a similar setup on my new motor, only i plan to run a 4150 series TB for the reasons listed above. Do you have any pics of the intake on the car yet? I have that exact NX DP kit that I will be installing so i'd like to see the clearance problems your having. maybe I can help you brainstorm on a solution.
I do not have any pics yet but I can tell you that the rear nitrous plumbing you see in the photos comes in contact with the metal cowl. I will hopefully get some pictures this weekend
Greg Jr. hahaha yes we're having to rethink the plumbing. We are working to avoid loosing the passenger side windsheild wiper. Not that I will need it but this is a street car
