Drag Racing Tech
How to hit 11s with bolt ons
Old Jul 9, 2009 | 04:41 PM
TA1364's Avatar
Default How to hit 11s with bolt ons
Mods: Vig3200, trans go shift kit, ls6 intake, p&p throttle body, hooker Lts, ory with moroso spiral flow dumped before axel, 15" wheels with 15x8 Et streets out back. Best the car went was 12.78 @ 105 with 1.75 short time.
I am adding a pt4400and getting it tuned tomorrow. I am going to shift it at 5900. What else can I do besides gears to help hit 11s SI? I was thinking Lca and relocation brackets. Any advice/opinions would be great.
Old Jul 9, 2009 | 05:54 PM
taws6m6's Avatar
weight reduction, get the 60' down more. I am not sure how high you should shift, idk where power would fall off with just boltons
Old Jul 9, 2009 | 06:10 PM
SmurfLSX's Avatar
your mph seems off. my auto bolt on car went 108mph with a DA OF +2400
Old Jul 9, 2009 | 06:32 PM
01ws666's Avatar
+1 Mph seems low are you tuned for your mods? What elevation and DA was your run at? You can use drag times density altitude calculator to find out. I was trapping 110mph with Lid, p&p tb, ls6, LT's, true duals, 2800 TC, 3.73's on MT et's. But that was with a efi live tune for my mods...
Easiest way to hit 11's SI is weight reductions and full susp/ slicks/ skinnies to dead hook that bitch...
Old Jul 9, 2009 | 07:01 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
QA1 front shocks would help.
I think to run 11.9x you will need to hit 112-ish mph.
I'd also try to shift at 6000-6100. Make sure that the combo does not shortshift otherwise you will run low mph and only run mid 12's. The shiftpoints will probably need touching up with the PT4400.
We use to stall that converter up two footing, great converter.
Old Jul 9, 2009 | 10:10 PM
KL20's Avatar
back in '03 when i was still SI, with bolt-ons (macs/ORY/vig3600) i ran 11.8 @ 111 w/ 1.6 60'. i had grandsports up front and salad shooters with BFG dr's. the only lb reduction i had was no backseat and took out my driver seat and replaced it with the passenger side. so basically not much weight.
Old Jul 9, 2009 | 10:21 PM
michaelz28lt1's Avatar
What kind of gears do you have out back?
Old Jul 9, 2009 | 10:24 PM
TA1364's Avatar
Yes the 105 mph isnt what I am looking for. I know vigs arent known for there mph tho. The car hasnt been tuned at all. Its usually pretty humid around here during summer.
Sometimes even with this smaller stall it chatters the tires off the line. I am sure qa1s would help. Mph is going to tell the whole story tho.
Ive lost 75lbs in wheels/tires, took the catback off 40lbs, sway bar and spare tire/jack.
Old Jul 9, 2009 | 10:26 PM
TA1364's Avatar
Stock 323s. I dont want to put any money into the 10 bolt.
Old Jul 10, 2009 | 11:23 AM
ShevrolayZ28's Avatar
Is such a pt4400 stall a good combo with stock cam?
Old Jul 10, 2009 | 11:42 AM
lemons12's Avatar
you need to move your shift point up some.. i would go to around 6150 with the limiter set at around 6400-6500..
take weight out..
make sure you are dead hooking on a small tire..
a set of 373s is going to help you a lot..
Old Jul 10, 2009 | 12:44 PM
TA1364's Avatar
Guys have good pretty quick on the SI list with this converter. I wont have a stock cam for ever, eventually I want to do an ms3.
take weight out..
I dont want to do gears untill after a cam. Even then I'd rather wait untill the 10 bolt broke. Lca and relocation brackets are fairly cheap. That should help me dead hook.
Old Jul 10, 2009 | 01:44 PM
Shon Herron's Avatar
3200#s here with headers/full exhaust, tune, PT4400, 4.10 in 10bolt, with the right suspension.
see sig for best time (1/8th mile). It has went consistant 11.7s in the 1/4 with a best of 11.59.
Old Jul 10, 2009 | 03:16 PM
lemons12's Avatar
for 150$ you can have gears... and if it knocks off 2/10s... well worth it to me..
but its your car!
Old Jul 10, 2009 | 10:35 PM
promod1955's Avatar
Remember what I told you about the shift points with that stock cam. Is there any way your tuner could come to the track so you can adjust the points while there and make some passes to see what it likes?
Old Jul 10, 2009 | 10:38 PM
promod1955's Avatar
I got a nice 10 bolt that will buy you some time too instead of dumping $2200 on a 12 bolt or 9".
Old Jul 11, 2009 | 12:49 AM
TA1364's Avatar
but its your car!
Now if I could install gear by myself then that would be a deal!
Yea hes willing to come to the track. Got the converter in tonight 1-2 shift is a little low and falls down to about 5k but 2-3 is close to 5900 and it doesnt fall down as far. Unfortunatly I wont have it tuned for the track tomorrow but I'll see what happens.
Old Jul 11, 2009 | 02:27 AM
lemons12's Avatar
find someone that is wanting to get a higher gear (323s 273s etc..) or going back to stock..
tell them you will trade, do the work, and give them 100$... just test their rear end out before you get it.. just trying to help think of ideas to get you into the 11s..
Old Jul 11, 2009 | 02:43 PM
TA1364's Avatar
No times today, rained out.
Old Jul 12, 2009 | 11:08 AM
BigKap94z's Avatar
I would also try installing a cutout, or removing that spiral flow. I have had reports of that muffler losing considerable hp when used on a single exhaust setup. It may be worth a try.
