Drag Racing Tech
Shocks hitting Spohn sway bar?
Old Aug 10, 2009 | 01:17 AM
TS6's Avatar
TS6
Default Shocks hitting Spohn sway bar?
I know this setup usually runs close, but I was at Burkharts today and he mentioned that they had some cars have real problems because the shocks (QA1's) were hitting the Spohn drag sway bar and binding. So I got home and checked, and mine are rubbing. I'm not sure if relocation brackets (like chuck and madman sell) will fix this, as they move the shock forward but not sideways to make more room.
Anyone know what to do?
Old Aug 10, 2009 | 02:18 AM
camscam02's Avatar
you can go with the relocation brackets, It is usually the **** that is hitting the bar? As im sure you know the bracket turns the shock and **** out and then you can also weld the brackets further to the left or right a little to gain the room needed.
I have experienced this on a couple cars with single and dual adjustables not wanting to fit. The brackets fixed all of them.
Old Aug 10, 2009 | 03:59 AM
Jimmy P's Avatar
https://ls1tech.com/forums/suspensio...-drag-bar.html
Does it look anything like this? Its not good for anything in the suspension to be binding. It was causing my car to squat funny and it was launching crooked. I ended up ordering those weld in relocation brackets from Madman, but they didn't work with my Strange double adjustables. If you do order them, call him up and make sure you describe your shocks very well as there are different variations. We ened up just relocating the shock mount a little by welding in a thick washer. Worked out great and the car was launching straight again.
Old Aug 10, 2009 | 06:26 AM
tektrans's Avatar
Mine is real close to the shocks as well, not hitting though.
Old Aug 10, 2009 | 09:09 AM
TS6's Avatar
TS6
Yeah, looks like the same issue. I'll pick up the relo brackets from Burkhart this week when I get my brakes, see if that helps.
Old Aug 10, 2009 | 09:18 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Mine were tight but did not touch.
Old Aug 10, 2009 | 09:33 AM
BlackScreaminMachine's Avatar
Internet Mechanic
IF we were to use that Bar with those shocks, using a hammer to do a little clearencing, would that take the rigidity out of the bar??
Old Aug 10, 2009 | 10:05 AM
tektrans's Avatar
That bar is a solid piece. You ain't hammering sh*t on that thing.
Old Aug 10, 2009 | 10:54 AM
Internet Mechanic
Ok, good to know as I will be putting on my set of QA1's and that might be the rear bar I get, how about then grinding??
Old Aug 10, 2009 | 10:57 AM
Jimmy P's Avatar
If you looked at mine while the car was just idling, it wasn't touching. But after driving it like that for a few months, you could see where the bar was grinding into shock. It would only touch on the launch.
Old Aug 10, 2009 | 11:07 AM
kp's Avatar
kp
Only thing you can do is move the lower shock mount inboard a little, you can also roll the bar forward on the rear axle tube if the mounts arent welded and get a little more room.
Either way its a pain in the ***, I had no issue with the Spohn except for that, thats why I put a BMR on this car. The BMR is curved around the shock and has a ton of room.
Old Aug 10, 2009 | 11:13 AM
Jimmy P's Avatar
It also seems to be a problem only with the Moser housings. My buddys that have the same sway bar, but on a Strange Dana and Strange 9" aren't having those issues. My new rearend is a MWC 9"..and it has plenty of space as well without modyfing anything.
Old Aug 10, 2009 | 12:23 PM
kp's Avatar
kp
It depends how you mount the sway bar as well, like I said if you roll it forward you get more room. Its possible the center to center between the shock mounting points may be a little different between brands but I had the same issues with a strange 12 bolt and the spohn bar hitting the shocks.
Old Aug 10, 2009 | 01:10 PM
LS1Tech Co-Founder
Mine was a Moser 9" and did not touch, but I ran the BMR bar in the white Camaro and it's run a bit better like Kevin said.
Old Aug 10, 2009 | 01:49 PM
Internet Mechanic
This is all good info, but like said, can we grind it a little just for clearence purpouses or does it fatigue the metal??
Old Aug 10, 2009 | 02:07 PM
tektrans's Avatar
I have the Moser 12 bolt and it's fits well, close but fits.
I really wouldn't go grinding on it Black, plus I'm pretty sure it's powdercoated so you'll compromise it. I would just go with the BMR if it's gonna be an issue.
Old Aug 10, 2009 | 02:27 PM
Internet Mechanic
Yea, thats my issue. I got the 12 bolt, I got the shocks on a stock sway and after learning on cars like JL, I know stock will be a liability.
Aside from a bar from TRZ, the Spohn or BMR with the Poly bushings have some give as opposed to Wolfe which is welded. I do want some given and I figure do the research now.
Thanks for the advice.
Old Aug 10, 2009 | 05:11 PM
ShevrolayZ28's Avatar
Mine would not clear my Koni shocks on my Moser 9", so I ground notches into the bar to make it fit.
Old Aug 10, 2009 | 09:28 PM
phoenix's Avatar
i am having the same problem, i tried to notch the sway bar but i am still having problems. i am going to toss it and buy a wolfe
Old Aug 10, 2009 | 11:04 PM
BlackWS666's Avatar
Dude mine has rubbed since install, but like everyone is saying just the shock adjustment.
