Drag Racing Tech
NGK TR6 plug gap???
Old Aug 26, 2009 | 03:22 PM
RENE'S RAGE's Avatar
Default NGK TR6 plug gap???
What gap do you set these at, for N/A. I've always ran TR5 and gap them
@.035. My compression is around 11.7:1. Thanks George
Old Aug 26, 2009 | 04:50 PM
jmm98LS1's Avatar
.035" is where you want them
Old Aug 27, 2009 | 04:08 PM
Thank you, Sir!
Old Aug 27, 2009 | 07:12 PM
Randy WS6's Avatar
I run mine at .038".
Old Aug 29, 2009 | 11:16 PM
jsafe's Avatar
2x for .35
Old Aug 29, 2009 | 11:17 PM
1BAD_LS1's Avatar
Restricted User
ran mine at .35 and it worked great
Old Jul 28, 2013 | 06:30 PM
KillerBermzZ28's Avatar
So .35 it is! Thankx!
Old Jul 28, 2013 | 07:22 PM
Wow!
Old thread, but let's get alittle update.
So what's everyone gapiing these plugs at now.
Old Jul 28, 2013 | 07:27 PM
HCI2000SS's Avatar
Ran mine at .040" and they worked great
Old Jul 29, 2013 | 11:01 AM
VandykeT/A's Avatar
Mine are 0.040.
Old Jul 31, 2013 | 02:38 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Originally Posted by VandykeT/A
Mine are 0.040.
X2
Coach
Old Jul 31, 2013 | 03:03 PM
Well, let's talk about this.
What are the pros and cons of a smaller gap and a wider gap.
For N/A motors.
Old Jul 31, 2013 | 06:53 PM
duh's Avatar
duh
My tr55's are gapped at .050 in my LT1. For N/A I've always gone with "as wide as your ignition can handle". Typically with a high energy ignition system you want as much gap as you can run without misfiring. This allows the flame to start and be more complete through the entire combustion process. This is just my $.02. For N2o use I would start around the .035 mark and go from there using a tr6 plug for minimal nitrous use (most I've ever run on them is 150 shot)
Old Aug 1, 2013 | 09:44 AM
How wide can you go, with stock LS1 coils.
N/A.
Old Aug 1, 2013 | 10:03 AM
SuperSlow02's Avatar
I gapped my at .05 before. nothing but misfire, with any climb in rpm.
Old Feb 9, 2014 | 05:59 PM
z06ufgrad2002's Avatar
Mine are set to .043 and getting a little misfire. I will be changing to .038-.040 and see how that goes. Leaning towards to the .038 as that will give a little leeway when they begin to wear and the gap increases.
Old Feb 9, 2014 | 06:19 PM
FIVEPOINT7's Avatar
Mine are at .035
Old Feb 24, 2014 | 02:56 PM
Longbob's Avatar
It depends on your ignition. A short duration/high intensity ignition like a MSD 7AL2 would want a larger gap in the .045 ish range.
Old Feb 24, 2014 | 04:15 PM
SMOKNSS's Avatar
I have always ran the TR6s at .035 on motor and nitrous at about the same compression you have, never had an issue. IIRC I believe I even ran my BR7s at .035.
