QA1s vs Strange single adjustable rear shocks
I have the QA1s now and traction is pretty good.. is it worth it to switch over to the Strange S5270s? Any benefit? Thanks
If the QA1's are in good working order (no oil leaks etc.) you will probably not see much of a gain if any by going to the Strange units.
I do agree that the Strange units are a better shock over all....
I have the Stranges on my car front and rear. It took a little bit of track time to get them figured out, but the car is a consistent 1.43-.44 in the 60ft. I had the Comp 3 ways before and I picked up about .10 on my 60 when I changed.
I have the Strange single adjustables up front and the 3 ways in the rear and cut 1.47-1.50 60's depending upon the weather with a stock torque arm. I highly recommend any strange product!!
What are you shocks set at all 4 corners when you cut your best 60's?? Just curious...
