Drag Racing Tech
Which lines to loop(ps delete)
Old Oct 21, 2009 | 09:02 PM
taws6m6's Avatar
Default Which lines to loop(ps delete)
I have been searching, but only see "just loop the lines". Which ones exactly? I dont have my car in front of me to look right now. I am basically looping the pressure and the return right?
Old Oct 21, 2009 | 09:21 PM
studderin's Avatar
theres only 2 line off the rack
Old Oct 21, 2009 | 09:43 PM
taws6m6's Avatar
Just to clarify, I am looping the 2 lines off the rack, NOT the 2 lines of the pump correct?
Old Oct 21, 2009 | 10:12 PM
studderin's Avatar
well you can loop them on the pump if you want. But that **** gose in a box in your garage
Old Oct 22, 2009 | 02:37 AM
dlove's Avatar
Get off the internet and go look. It will make a ton more since.
Old Oct 22, 2009 | 07:49 AM
taws6m6's Avatar
ohhhhhh....sorry. brain fart. if the pump isn't there then the only lines to loop are the ones on the rack. thanks
Old Oct 22, 2009 | 11:25 AM
JL ws-6's Avatar
Race your car!
Depending on the car, you may, or may not need to get an upper heater hose to remove the cooler/heater for the rack to completely remove everything.
The rack, lines, are the ones that need to be looped. Circulate the rack some once you pull the pump with the tires in the air to work all the fluid out, that will make turning it a good bit easier. Did for me anyway.
Old Oct 22, 2009 | 11:29 AM
tee-boy's Avatar
Earl's make some #6AN fittings which fit the rack. Both fittings have an oring seal and have different threads (2 different part numbers). Get those 2 fittings and about 8" of #6 SS braided AN hose, and you just loop the 2 ports on the rack.
