Drag Racing Tech
"CAM ONLY" setup, I want to use LS6 heads?
Old 11-16-2009, 11:51 PM
studderin's Avatar
Question "CAM ONLY" setup, I want to use LS6 heads?
I'm thinking of staying camonly for a little longer still, And I guess you can put a LS6 motor in your Fbody and still be cam only? How dose that work?
Old 11-17-2009, 12:46 AM
slowlsx's Avatar
wouldnt be considered cam only IMO.... if that was true people would put an ls6 cam in their "BOLT ON ONLY" cars and be running much better. just my .02
Old 11-17-2009, 06:13 PM
Camaro396's Avatar
New one by me.
Old 11-17-2009, 06:29 PM
Race your car!
JL ws-6's Avatar
That's not right, ls6 motor doesn't count the same way. If it did, then I'd drop an ls7 in my car with a big snotty cam and go after the cam only record.
Ls1 cam only, is a 97 thru 2002 ls1 motor, you can do anything you want externally, heads can come off to flycut... but the original heads must go back on (casting #) and the heads can not be milled/touched at all. Gaskets must be a GM gasket, mls ones is fine. Valve springs o.k., no aftermarket valves, bottom end can't be touched, although alot of guys do put rod bolts in so they can wizz it higher, I don't really think that's right.
Old 11-17-2009, 07:12 PM
SSPerformance's Avatar
deff not right. Exactly what JL said. We run a STOCK UNTOUCHED 241 head. I don't Believe you should be allowed to flycut......
Old 11-17-2009, 07:40 PM
BadBandit69's Avatar
cam only fastest list
I also wondered this when i saw #19 made the list. He has 243 heads and i also think that shouldn't count, but i just figured i was the only one who thought this so i didn't say anything lol. The list does say ls1/ls6 but shouldn't that only apply to the block?
But i feel flycutting and rod bolts should be allowed, but no changing pistons. BTW i have neither so im unbiased. I just take the chance and spin my 00 block to 7200rpms.
Old 11-17-2009, 08:30 PM
DarkJuggalo's Avatar
well i mean shoot, my opinion if your going cam only then there shouldnt be Tubs, 9"/12bolt, huge diet, or a cage. but thats just me. i think cam only should be cam only
Old 11-18-2009, 05:19 AM
Nitroused383's Avatar
I have never seen any internet race cam only classes at my local track?? Where does one verify the car is cam only besides internet post? Say what you want but the internet class thing is retarded with out tech officals at the track tearing cars down to see if they really are "cam only".
Can you really verify someone doesn't have an offset ground stock crank and touched up stock casting heads? If someone wants to make a class why don't they make a " stock appearing class "
If there truely are cam only races how is this fair for other people going for the record who live at higher elevations? Not all tracks are open all fall and winter long to run in amazing air. Doesn't seem like a fair class at all. Heads up racing seems the only fair way.
Old 11-18-2009, 08:39 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,113 Likes on 730 Posts
Swapping on LS6 heads was not in the spirit of cam-only when we first started talking about it 6-7 years ago.
John
Old 11-18-2009, 09:37 AM
Turbo LS1 SS's Avatar
esp. your home ported 243 heads! oops
Old 11-18-2009, 09:45 AM
Magnet's Avatar
I had a problem with it when he first was posting his times and asked to be on the list, but noone else seemed to care so I just let it go. He says he has a "cam-only" LS6...which might be true, but it still doesn't belong on the list in my opinion.
Otherwise someone should put a "cam only" LS7 in their car and take the title..
Old 11-18-2009, 02:20 PM
Race your car!
JL ws-6's Avatar
Hell why stop there, I'll just get an LS9 crate motor, put the biggest cam in that I can and go probably faster then I have already.
cam only, is a stock ls1 motor, like what SS performance is running. That is a good example of a really good running cam only car. It's light, leaves hard and runs strong, exactly what the entire thing was about from the beginning.
It's not really open to all the ls generation of motors... if it was, like I said.. ls9 with a big *** cam here I come LOL.
Old 11-18-2009, 05:41 PM
Magnet's Avatar
How'd I forget about the Ls9?? That would be a sick car! lol..
Old 11-18-2009, 05:49 PM
NHRAFORMULA00's Avatar
You guys are getting too dam picky.So what if the heads only came on a vett,they are still 346 GM stock heads.But its Ok to put a 346 in a Mustang on this site.Its nothing more than internet racing,who really cares.
Old 11-18-2009, 05:53 PM
lemons12's Avatar
I don't think it is right either.
Old 11-18-2009, 08:47 PM
Magnet's Avatar
Were not taking anything away from the guys times.. they are really good. It just ruins the "cam-only" list integrity if someone has heads on their car...243's obviously flow significantly better than 241's...
They are the rules that were set-up way back when... no reason to change them now. The whole list is void if you can put 243's on the car all the sudden..
Old 11-18-2009, 09:53 PM
98blueSScamaro's Avatar
Oh boy Look what i did know LOL Sure pick on the guy who posted his time in the cam only list thinking they would put him with the vette's but what ever haha. I swaped a LS6 long block into my car cuz the 98's are Junk for the rpm i was looking to make and trap with just a cam in the ls6. Plus i was looking to go head cam setup go after the head came times as well but then i Meet chrs1313 and we turned into good friends And he talked me into maxing it out before the heads So i did And i did it with A 3475LBS M6 car but i dont care it's cool and all to be on the list and i saw it said LS6 so i posted my time and they added. Sorry To start all this
Rob
Old 11-19-2009, 02:18 PM
Race your car!
JL ws-6's Avatar
Personally, I don't think transplants (ls1 into a mustang) should count. If that's going to count, then putting on in an 1800 lb rail car should count too, and that certainly shouldn't be in the same arena
Old 11-19-2009, 03:26 PM
LS1Tech Sponsor
Slowhawk's Avatar
Do what you want.Cam only is only an internet thing.Alot of people pull the original heads to flycut.In my opinion why pull the heads without milling them and redoing the valvejob?That makes it more than Cam only but I'm sure a few of the "Cam Only" guy's did just that.
Old 11-19-2009, 04:42 PM
You read my mind.
Quick Reply: "CAM ONLY" setup, I want to use LS6 heads?
