LS1 Turbo 400 with transbrake (Need Help)
Anyone help me with what kind of two step, rev limiter etc. to use with a 2000 LS1 motor. I'm running a turbo 400 with a hipster brake in a S-10 with a Street and Performance harness. I know you guys are using transbrakes on these Camaros. Need to know if you are running some type of aftermarket ignition boxes to plug two step and rev limiter into. Have had no luck finding ignition box for distributorless ignition with 8 coil packs. Called MSD and they could not help. Any help would be appreciated. This is my first LS1 or fuel injected race car, so hopefully these are not dumb questions. Thanks in advance for any help.
The only two step for the LS1 is made by our beloved, and difficult to reach, Matthew Harlan. He is a moderator here and goes by y2khawk. Look here and check out his signature for info:
https://ls1tech.com/forums/forced-induction/120517-question-harlan-anyone-else-experienced-w-tach-wire.html
https://ls1tech.com/forums/member.php?u=22
