Tire height change affect on pinion angle
When I shorten my rear LCA's to pull tire forward (going from 26" to 28"), I expect my pinion to rotate upwards. Do you expect I will have to lengthen the torque arm to put pinion back in original position (-2 degrees).
what's your experience?
The pinion angle should not be affected by adjusting the control arms. The torque arm holds the pinion angle rigid regardless of the control arm length. When you shorten the CA's the TA and rearend will pull forward together and the TA will slide forward in it's mount(or rotate the front bushing depending on your TA setup).
