Drag Racing Tech
What Starter for Large Cube and High compression?
Old Dec 31, 2009 | 02:17 PM
SlickVert's Avatar
Default What Starter for Large Cube and High compression?
What starter are you use with large cube and high compression engine.
I have a 44oci and 14 to 1 compression.
Will the stock starter work or would I be better off with Powermaster or TCI?
Old Dec 31, 2009 | 03:39 PM
MADMAN's Avatar
LS1Tech Sponsor
We use the stock starter with a 16 volt battery. Powermaster would be a good choice for aftermarket.
__________________
www.madmanandcoracing.com
225-343-9029
Old Dec 31, 2009 | 05:36 PM
tektrans's Avatar
I use the stock starter with my 13:1 441.
Old Dec 31, 2009 | 05:41 PM
silverz28camaro's Avatar
I think the main thing would be to make sure you have very good and clean connections, also I like to use dielectric grease on everything elec. related.
Make sure your battery is big enough and is always fullt charged, even on stock motors I beleive that a well maintained battery will improve power output as well, by alowwing the alt. to work less during re-charge after a start. If my car ever sits more then a week, I will put it on a battery tender. I have got more then 6 years out of a atv battery this way. When batteries go dead, thats when they lose most of life and power.
Let us know what the car runs when its up and running.
Old Dec 31, 2009 | 07:07 PM
SlickVert's Avatar
Thanks for the advise, I will try the stocker to begin with.
Bob
Old Jan 1, 2010 | 01:15 AM
promod1955's Avatar
I've used the powermaster with good success
Old Jan 1, 2010 | 06:34 AM
tals7's Avatar
Smile
stock should be fine.i use the msd unit on my 12-1 ls7.tried the powermaster and jegs unit and they would not work with my 2in arh,s.
Old Jan 1, 2010 | 08:17 AM
JL ws-6's Avatar
Race your car!
I have a powermaster on my car, it cranks it over a 13.5 to 1 402 with no problems, with a 12 volt battery.
You use a 16 volt battery and the sky's the limit, you can pretty much start anything.
Old Jan 1, 2010 | 06:44 PM
Firehawk441's Avatar
I've used a stock starter with more compression then this with no issues.
Good battery cables and connections are always very important!
For what it's worth:
Static compression isn't the concern.
Dynamic compression and monster valve springs for a solid roller application are of more concern.
Old Jan 2, 2010 | 11:55 AM
mdacton's Avatar
I have a start retard in my box, its helps
Old Jan 2, 2010 | 02:18 PM
ericg69ss's Avatar
Ditto. I used a powermaster on my last set up, 13.5-1 compression 427 with a .700" solid roller.
