CSI supershield vs Hughes flexplate shield and RCI Trans blanket - thoughts?
LS1Tech Co-Founder
I picked up a new CSI supershield from a buddy, and it's super light. That's good. But it looks like as folks said, it will be murder accessing the bellhousing bolts.
Would a flexplate-ONLY shield and blanket be an easier combo to install?
the thing im lost with is why does it matter if its difficult to pull/put the trans in when Dan is going to be doing it anyways?
John,
One trick we use is to mark the position of the top bell housing bolts on the firewall and drill holes for access from the inside. They are normally under the carpet and makes servicing much easier.
"The Drag Racing Director"
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
[QUOTEJohn,
__________________
Billingsley Racing[/QUOTE]
Now, this a great idea!
Thanks man!
Coach
__________________
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Coach
LS1Tech Co-Founder
None of the guys over there including Dan have ever installed a CSI supershield into a 4th gen f-body, so I thought I would ask to see if there were helpful hints.
The Bull
I run an ultrabell and a blanket. When I wrap mine with a blanket it never overheats or gets excessively warm. And yes, drilling holes through the floorpan is definitely the way to go.
