My Stock Internal M6 buid thread...10's???
#204
Hey TK! You need to come race tomorrow and shoot for low 12's in the vert! By the way I know how much I have taken out, just not how much it started at
Im pretty sure I'm within 20lbs on my estimates.According to my scales, I have taken 581.85lbs out thus far ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Oh and I tried weighing at a scrap yard once and turned around and left because the dirt was so filled with screws, nails, and other shrapnel it wasn't worth leaving with 4 flat tires over..
Silly question, how did you measure your fuel pressure at WOT? It would be nice if you gained some from the swap!
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
![Icon Cool](https://ls1tech.com/forums/images/smilies2/icon_cool.gif)
#207
Might want to look at the fuel pump too....if you already haven't. Last time I ran my car it was down to 30-32psi of fuel pressure going through the traps.
Now it's got a racetronix pump/hotwire and asa injectors - I'm wondering if it'll pickup....took a complete retune to get the afr's back in check.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
#212
Dang.. Im giving all my info to the competition! lol
I'm excited too, There hasn't been a documented stock internal car that I know of that has had everything I am going to have... doesn't mean it will be faster, but it sure will be interesting to see the results.
I am not gonna lie, Im really hoping that between the 104mm Lid, 100mm MAF, 102mm TB, 102mm intake, EWP, 1-7/8ths headers, and a real AFR tune I can pick up 2 tenths and mph... but who knows!!
Typically I've been good at taking weight out, NOT at making the most horsepower!![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I'm sure you'd have two tenths and maybe two MPH in the tune by itself. It's going to need a tune really bad after you swap over to that 104mm lid and 100mm MAF. Anything you change to the MAF or to the intake tract before the MAF will throw the calibration off. My stock MAF calibration changed about 10-15% from just swapping the stock air box to a crummy whisper lid.
#214
Ive preached it before, and Im gonna say it again, because it is the ONLY reason no one has broken the M6 SS record yet.
GEAR AND TIRE!!!
Get the combination right - the hardest part is getting the damn car off the line without spinning, and without bogging.
Higher gear,taller tire...
Oh and as an FYI, when I was SI, I was on the stock LS6 type intake, stock balancer, and didnt have much weight out of the car.
GEAR AND TIRE!!!
#217
If you don't pickup at least 2 tenths after all that and dropping 50#s+ you'd probably be doing this >>> ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
GEAR AND TIRE!!!
GEAR AND TIRE!!!
