My Stock Internal M6 buid thread...10's???
#122
I write checks with my mouth that my ass can't cash
i have no pics i havent done it, but iv been there and helped about 4 friends do it....you take your fender off and there is metal under it you start with a sawzaw and just go along the seam and cut it out....its 5lbs per side 10 lbs total...i cant belive you havent dont this yet ! (also what lightweight battary are you guys using and where can i find it)
#124
battery: got mine from modularturbo sponsor on here comes with a 1 yr warranty and if it doesn't start your car he will give an instant refund... 100 shipped iirc weighs 11.5lbs
#126
I guess I will take off the plastic fenders and decide if I want to hack it up that much or if it can be hidden...
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
No offense, your just up on all this stuff so I would assume you would know about that..
#127
its COMPLETLY hidden, and its a very simple mod theres even a little hole already to start the saw....you will be the only one that knows its done, make sure you have a buddy with a pliers to pull it down as you go and cut right along the fender line...
#129
front bumper support, front sway, traction and cruse control, carpet insulation, egr/air, rear bumper support, all the heat shields and a few other odds and ends im sure im forgetting...also a chromoly tubular k-member should be here any day and im ordering a lightweight battary
#131
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I will check it out some stuff I am not willing to remove...
#137
#138
#140
same here, everything i have done is reversable....and by the way i contacted LG motorsports and they discontiunued the aluminum LCAs and PHB for the 4th gen because they started the 5th gen stuff...so you can no longer get them
