Drag Racing Tech
front suspension
Old Sep 29, 2010 | 07:09 AM
camaroturbo's Avatar
Default front suspension
time to do the front susp this will be a 80% drag car 20% street car am not sure wut a-arms to get adjustable or non and wut eles should I get for the front setup thx
Old Sep 29, 2010 | 07:14 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I am not too bad when it comes to grammar and spelling but good god.
Aside from the comment, I would say you need to explain more about the engine combo, power, race weight, gearing, drive train, tire size. Sure we can all suggest things but in order to give proper advice, I think we need a little more.
Old Sep 29, 2010 | 08:04 AM
ok its a 94 camaro gen 1 sbc 383 88mm turbo its about 3800 to 3900lb not to sure I have the rear susp all done with afco da auj TA , CA and panhard bar best 60 foot this years is 1.52 with the front susp and k all stock. it has 3.73 gear th400 295 50 16 m/t dr on stock rims not sure on the power mybe around 900rwhp the car traps 143 mpr
Old Sep 29, 2010 | 08:12 AM
Steve Burger's Avatar
LS1TECH Sponsor
Give us a call and we can talk over your project. Adjustable stuff is the route you will want to take. We can also do a 1" per side narrowed front end to give you a bit more tuck on the front tires.
Old Sep 29, 2010 | 09:24 AM
how would that look with stock rims and wut does it help by narrowing the front ?
Old Sep 29, 2010 | 09:40 AM
Old Sep 29, 2010 | 11:05 AM
LS1TECH Sponsor
A 1" narrow will not work with stock rims. It does help pull skinnies in. It was just an option that I mentioned.
Old Sep 29, 2010 | 11:49 AM
o ok ill prob try to give you call see wut we can do thx for your input
Old Sep 29, 2010 | 02:40 PM
armyboyatc's Avatar
Well, if you want some opinions on here as to what you should do, post up your power level and what your current mods are and people will begin to help you out. We need to know what we're workin with here haha.
Old Sep 29, 2010 | 08:19 PM
its in post #3
