Yet another 275 Radial Build
#61
We had a competitive true street car and wanted to go up a class and run with the cars running 5.0s and it cost another 50 grand to go from 5.5s to 5.0s. 2 years later we still have not made a pass down the track. BS3 was bad and we were unable to find the problem. Of which time we blew the heads off of it several times because of the bs3.
We have a speggetti menders on the car to make wiring a cinch.
Just a word of advise. You will be fabricating tons of stuff. Buy everything you can already built. It will make your life so much easier. It cost a little more to do it that way but if you don't, you will end up making some half *** stuff and it will take forever to get all finished.
This is my 4-5 build and I learn so much each and every time. Also, go to big races (out of state possibly) to watch. Go through the pits and just look at all the F-bodies. You willl get tons of really good ideas.
#62
Didn't get as much done this weekend as I wanted to but still got the seat installed and some wiring cut out. With the time change I should be able to work on the car after work and get the rest of the wiring out, leaving only the connectors I need.
The seat sits lower than the stock one but should leave a lot more room for my helmet, I was always smacking it against the t-tops before. It will be harder to see the nose of the car but I don't think it will cause too many problems.
Here are some pictures of the seat and bracket installed.
#67
Race your car!
Bob and Jay... those guys are the ****. Those guys get stuff done faster then ANYONE, and the quality, is nothing short of amazing.
You're a very lucky man to have them local enough to you. Hell I still may use them myself, and they're over 1000 miles away.
But, I know I can drop my car there, and in 2 to 3 weeks it's totally done with a back 1/2 and a 25.3 spec chassis, hood mounted, dash mounted, all the tin work done, etc.etc.
I don't know of anyone else that can get stuff done like they do. You put a car in their shop, and it's DONE FAST, and DONE RIGHT.
#69
#74
#79
Sean
