Drag Racing Tech
9s CAM ONLY new record !!!!
Old Feb 13, 2011 | 12:38 PM
  #121
Bhogan909's Avatar
Why post pictures under the hood now? People wanted to see under the hood when the cam only setup was still in the car. It's obviously you have some type of 4" turbo horn style inlet for a ram air type setup. I don't understand what was so secretive. Here's the way I see it, if you're going to claim an "internet title" then what do you have to lose by showing what you have unless there is something there that you're hiding?
Old Feb 13, 2011 | 12:42 PM
  #122
Bhogan909's Avatar
Here are a few things that I think would clear a few things up:
1. What kinda horsepower did the car make (flywheel or rwhp)
2. What was the density altitude on the date the car made the record pass?
3. Why was race fuel necessary when the compression was stock? Anyone that's been on a dyno knows that a stock LS1 isn't going to gain from some type of extraordinary timing maps of mid 30's to maybe 40 degrees of timing?
Old Feb 13, 2011 | 12:59 PM
  #123
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Big time congrats. Car turned out great. Good luck this season.
Coach
Old Feb 13, 2011 | 04:55 PM
  #124
SSPerformance's Avatar
1. a little over 400rwhp
2. -200 da nothing killer
3. you know everything figure it out your self
Old Feb 13, 2011 | 05:02 PM
  #125
Nothing to hide here. everyone at the track can vouch....
Old Feb 13, 2011 | 05:04 PM
  #126
studderin's Avatar
its a LS1 swap car anyway and don't count
F-body
1. Smokin01ta 10.219 @ 132.29 (1.38), 01 T/A, LS1, M6, Spec4, 4.56, TRex, -1100, 3010 lbs, 3/06
2. LS1Joe 10.232@132.04 (1.39), 02 Z/28, LS1, M6, Spec4, 4.71, 250, -1100, 3150, 03/06
3. 01-Z 10.295 @ 128.48 (1.38), 01 Z/28, LS1, TH400, 5500, 4.57, G5X4, -110, 2880, 4/05
4. Magnus 10.295 @ 128.48 (1.36), 97 Firebird, LS1, TH350, 5500, 4.10, G5X4, 200, 2820, 4/05
5. Dragaholic 10.340 @ 127.46 (1.36), 00 SS, LS1, TH350, 5500, 4.56, TRex, -700, 2850, 11/05
Corvette
1. Roger White 10.869 @ 123.04 (1.46), 02 C5, 4l60e, 4400, 3.90, M2,-1000, 3350, 11/03
2. Redgar 10.968 @ 124.66 (1.50), 99 C5, 4l60e, 5000, 3.90, VD, -800, 3400, 11/05
3. Robz 10.968@124.32 (1.46), 03 Z06, M6, Cartek, 3.90, 2x, -1000, 3250, 11/03
GTO
1. Joeyelbows 12.186 @ 114.35 (1.78), 04 GTO, M6, LS7, 3.46, 207/220, DA unknown, 3500 lbs, 12/08
Hybrid / Conversion
1. SSPerformance 9.986 @ 132.27 (1.31), 94 Z/28, LS1, TH350, ATI, 4.33, TRex, -270, 2900 lbs, 11/10
2. Ablakez28 11.021 @ 126.01 (1.557), 93 RX7, LS1, M6, LS7, 4.10, TRex, DA unknown, 2650, 7/10
3. cnichols 11.849 @ 122.74 (1.82), 96 240 SX, LS1, M6, LS7, 3.92, MS3, 600, 3000, 11/08
Old Feb 13, 2011 | 05:16 PM
  #127
F-body
Corvette
GTO
Hybrid / Conversion
LMAO... ok studderin drop ur car off be ready in 3 weeks...anyone else notice we out 60 EVERYONE 1.31 60!!!!!!!!!!!!!!!!!!!!!!
Old Feb 13, 2011 | 05:24 PM
  #128
Firehawk441's Avatar
Originally Posted by Josh@KY-Turbo
JL's guidelines look fine.
Get over the Fly Cutting. It is not a performance mod in it's self. If anything you are lowering compression. Diminishing performance .
It does allow you to run a larger Cam. This increases performance. IE: "CAM ONLY".
Rebuttal?
Word it any way you can think of....Cut pistons still aren't stock.
Old Feb 13, 2011 | 05:31 PM
  #129
Josh@KY-Turbo's Avatar
They are stock Fly Cut Pistons. Its a modification to the "stock" Piston.
Old Feb 13, 2011 | 05:32 PM
  #130
TA1364's Avatar
So can I put an ls1 in a dragster, call it a hybrid and beat this record?
Old Feb 13, 2011 | 05:36 PM
  #131
Thank you for saying "MODIFIED". Now it's no longer stock.
Old Feb 13, 2011 | 05:38 PM
  #132
dustin99a4's Avatar
Lol a stock piston is just that, a stock piston. A fly cut piston will not make any more power than a piston that has not been cut and does not make it an aftermarket piston.
Old Feb 13, 2011 | 05:41 PM
  #133
A 94 camaro is no different then a 99 dumb ***
Old Feb 13, 2011 | 05:48 PM
  #134
KY turbo must be slow if your digging up old threads. Go build ur stock bottom end car
Old Feb 13, 2011 | 05:49 PM
  #135
chrs1313's Avatar
i pulled 1.35 with junk y pipe hurting me 30rwtq and only a weak 124mph...I bet i could have given you a run at the 60ft title
that is a sick time and the car is working nicely...my h/c cant even run those numbers
  #136
I might possibly know that the modified piston by itself won't make more power. Only the clueless would cut the piston, lower the static compression for a cam profile that doesn't need the room.
The material removed from the pistons for these valve reliefs will however make the pistons lighter. This will have different effects that I'm not getting into here.
The larger camshaft that will now fit because of these modified pistons WILL make more power.
Old Feb 13, 2011 | 05:52 PM
  #137
Originally Posted by chrs1313
i pulled 1.35
That's very good with these lower power levels. Nice job.
  #138
kmracer's Avatar
is that like porting stock heads?
Old Feb 13, 2011 | 06:02 PM
  #139
studderin's Avatar
3 weeks, thats fast
Old Feb 13, 2011 | 06:06 PM
  #140
Nice 60 and you have a 4l60e correct ?
