Engine angle Pinion angle????????
The negative 2 degree pinion angle for all cars is one of the worst internet myths around....it's broken a lot of u joints and shafts.
Different planes is not a problem since most are built that way. Goal is to phase the u joints under load.
About your engine's position? Put it where you need to, and don't worry about the driveline's relative angle with the ground line or horizontal.... aim the driveline at the pinion centerline with the chassis as close to race ride height, with the necessary clearances you need to mount exhaust and accessories to the engine. Of course, avoid left/right axial misalignment of the driveline, and don't mount the motor sky-high! Your short wheelbase, lightweight car should wheelie fine without a high center of gravity.
Best of luck!
That is not the myth. The myth is "all fbods should use a -2.0 degrees down pinion angle for best traction". and that's a true myth if ever there has been one....lol..
