How many drag racers i'n here run a ram air setup
I've seen the results and I know they work just curious if there worth it once ur to a certain level anyone i'n here running them 10's and faster
Every little bit helps at the track. Here's a thread on the Mega Mouth. WS6 has them on sale right now.
https://ls1tech.com/forums/generatio...ts-inside.html
check my build thread for some pics. when I was testing cams and had the rad. out I know I snaped some of the ducts better. and look at motor pics with the lid off when I was doing that, and the intake test you can see the foam.
my front bumper is out getting painted should be done tomarrow maybe. I can get some if you need, just got the ducts hangin off the airbox, looks like catfish whiskers under the headlights. haha
free horsepower, i woould run this on any set up, ive always wondered how much mph and intake diameter and velocity may cause a pound of boost? especialy on motors with 12.1 or even more that is especialy nice
save these I';m gona delete them here.
http://i2.photobucket.com/albums/y11...n/IMG_5040.jpg
http://i2.photobucket.com/albums/y11...n/IMG_4248.jpg
old pics
http://i2.photobucket.com/albums/y11...n/IMG_0062.jpg
http://i2.photobucket.com/albums/y11...n/IMG_0058.jpg
http://i2.photobucket.com/albums/y11...n/IMG_0059.jpg
http://i2.photobucket.com/albums/y11...n/IMG_0056.jpg
FYI seal it up. I didnt have the glued in foam in the front, just a 4x4 frost king brand peice pushed into the front of the airbox for a few weeks. Car was going like 83 8th and 114-115 1/4 and it would blow OUT (foreword!) a little and the car would run 83 and the 8th but only like 112 in the 1/4? pop the hood see the foam push it back in, next pass right back to 114-115 the **** works.
oh I also put a piece of black screen over the metal tin on the bumper. for some extra filter. I'd do somthing like that if you street drive the car. They get big bugs, and leafs and stuff driving at night and in the fall. Keep the air filter alot cleaner. And when took them off the bumper there was tons of **** on the bottem then fell between.
old pics
I have the chris1313 non ac ram air. I have not gotten a chance to run the car in good air to see what it would do as a new best, but it picked up 1-2 tenths in hot air. My best in good air is a 10.56 and the car would usually go mid 10.70's-10.80's in the heat. With the ram air in place it has run 10.59-10.68 in the heat.
