Car aims right under max acceleration
I have a suspension issue, I believe, and I don't have clue one where to start looking for a solution. The car is a Procharged M6 and is probably making about 650 to the wheels now on 16psi. The suspension is mostly stock with LCAs, an adjustable torque arm and Bilstein HDs. Stock PHB, springs, etc.
The issue I have is that when I'm going down the track, the car tries to turn right. It's like the rear end is trying to walk to the left around the front of the car. I have to countersteer to the left while under load and then quickly center the steering when I let off at the traps. I've had a close call or two in the traps because I didn't center the steering quickly enough after letting out of it.
This seems to scale with torque. First gear is always the worst. Even if I baby it off the line and then nail it, it's pretty violent. I have a video that shows it a bit, but it's not too bad because this was on a slower build with me countersteering a lot.
Once in the past I thought I had an alignment issue (turned out to be the front tires cuz when they were changed, the problem went away), but NTB said my alignment was dead on. I thought maybe my rear end wasn't square to the front because the LCAs have some adjustability to them with the rod ends. I put the car in the air and measured with a plumb bob front to back on both sides and corner to corner. As I recall, it was within ~1/16" on all measurements. I assume I'm in good shape.
Anyone have any ideas on this? Maybe an adjustable PHB to center the rear end perfectly? Perhaps a Watts Link? LCA relocation brackets to limit the squat in the back?
VIDEO: http://www.streetfire.net/video/d1sc...8th_685754.htm
They're the same tires left and right, so I assume they're the same diameter. Same age, experienced the same conditions. Shocks are fine. Not sure what would bind up in the suspension. What should I look for?
I know what this is (thanks Google), but I don't know how to check it or resolve it.
I'm not sure about the rear swaybar. From the video, it doesn't look like the body or axle are out of level with the ground. It looks to me like it's an even squat and an even plant of the tires. However, your suggestion of the LCA bushings sounds plausible. What you can't see from the video (or any of the others I have) is whether the rear becomes out of square with the front tires under load. If one of the bushings has failed, then presumably that side of the rear end could be allowed to move forward more than the other screwing up my rear alignment. Hmmmm....
Ended up being the driver's side LCA bushings were totally shot, and the passenger wide not far behind.
Any other ideas or answers to previous questions?
Edit: Like this
https://ls1tech.com/forums/drag-raci...4-how-bad.html
But if your running a 9.5" radial up front and a 10" rear slick your going to smack the wall..
You can run a skinny radial up front and a slick (bias ply) in the rear and be fine. But I wouldn't do it..
Hopefully that makes sense
https://ls1tech.com/forums/drag-raci...8-wipeout.html
If it's pulling right, I would think the pass. LCA is effectively shortening itself.
My friends car was shortening the driver side and pulling to the driver side.
Measure the circumference @ the same psi. [Have you tried to swap the tires side for side?
Shocks may look "fine". Could well be 1 of the suspension binding points, if they are different rates.
Other bind points are as mentioned in other posts...
You can set the car on jack stands. [Under the body, not the axle.] Support the axle on a jack, drop the shocks loose, and raise/lower the axle to check for binding...
Edit: Like this
Skinnies are in the works, though. Thanks for the suggestion!
